Crank spacer needed for 4l80e swap?
Old Sep 24, 2005 | 10:53 PM
Blackdog76's Avatar
Default Crank spacer needed for 4l80e swap?
I have a 2002 Denali and I've decided to go with the 4L80E. I read somewhere that I will need a crank spacer behind my 6.0 unless I have a 99-00 motor. This is the quote : "You will need the crank spacer for anything except a 99-00 6.0 motor" Is this true?
Old Sep 24, 2005 | 11:23 PM
99Silver6.0's Avatar
Its correct. 2000 and earlier motors had longer crank shaft and had no need for the spacer. Now on an 01+ you will need the spacer/bolt kit and flywheel for an 80E. Speed Engineering sells it cheap.
Old Jul 27, 2023 | 02:52 AM
150096Suburban's Avatar
Registered User
Default Need help of true 4l80e putting it a 5.7 vortec
I have a 1996 Chevy Suburban 1500 4x4 and I put a 4l80e in it and wondering do I need a spacer for the flex plate or is that only for ls only .
Old Jul 27, 2023 | 07:52 AM
strutaeng's Avatar
5 Year Member
That's only for the LS. I'm assuming you are also replacing the flex plate? The 4L60e torque converter has 3 bolts vs 6 for the 4L80e torque converter.
Are you also swapping the input shaft of your transfer case to fit the 4L80e?
Edit: Ho-Lee batman, this is a really old thread revival!
Old Jul 27, 2023 | 11:45 PM
_zebra's Avatar
makes children cry
it's also incomplete in that this caveat additionally applied to a handful of 99-00 4.8s, too.
Blackdog76
Feb 16, 2022 12:22 PM
SDjeff619
Jul 20, 2017 12:14 PM
HydroStream6
Apr 8, 2013 12:07 AM
V30blazer
Feb 13, 2009 06:40 AM
LIL SS
Dec 6, 2006 08:58 AM
