4l80e upgraded flexplate
I believe I ended up with a 99-2000 "long crank" in my short block. I'm swapping to an 80e and wondering what flexplates have any of you used that had the early 6.0 long crank? P/N, spacer used or pilot extender sleeve? I intended on going with the tci flexplate but not sure between the 399753 and 399754.
Thanks, I talked to Brian at Circle D and got some good info. Then found that JW in Florida makes a flat flex plate that works with the long crank. It's on order.
