Cooling Trans
Old May 20, 2013 | 10:48 PM
Slammed96's Avatar
Default Cooling Trans
So I had the truck out tonight, stopped to talk to someone and let the truck just idle. Sat idling for maybe 20 min or so, and when I got in the trans was almost at 150* which is a bit higher than I would like it to get. Highway driving the temps are usually around 115-125 or so. Should I go ahead and bypass the radiator, or install a pusher fan in front of the cooler? Truck has a 3200 stall and Tru-Cool 40k on it. I do tow occasionally and also do some hauling once in a while.
Old May 20, 2013 | 10:55 PM
slammedsilvy's Avatar
150 is nothing to worry about at all in my opinion, that's still on the chilly side. I've ready the ideal temp is 175 or so, mine usually runs cooler than that and I'm fine with it.
Old May 22, 2013 | 08:19 AM
Slammed96's Avatar
I'm just worried if it gets that hot sitting at idle, how warm might it get pulling a load in stop and go traffic. Maybe I'm just being overcautious though.
Old May 22, 2013 | 08:41 AM
nonnieselman's Avatar
over cautions.. just keep it under 200 and you will still be ok.
i idle mine almost 45 min each day eating lunch and mine never breaks 160. and its been in the low 90s here.
Old May 22, 2013 | 02:27 PM
charcoal03silvy's Avatar
its fine, but I would bypass the radiator. I learned the hard way... tank busted and got coolant in my trans fluid.
Old May 22, 2013 | 02:38 PM
Yea same here.. i bypassed my Rad cause the cooler was clogged up.. nothing but a TruCool 40K now.
Old May 22, 2013 | 06:28 PM
custm2500's Avatar
Ph.D. in HUBRIS
The reason for you warming at idle is the radiator. You have nothing to worry about but if you want it to stay lower then bypass the radiator.
Old May 22, 2013 | 06:45 PM
outlawz2004's Avatar
mine has ran at 200-210 its whole life. Original trans was beat on and still working with 206000 miles on it. My new trans is running about 200 in 90 degree temps outside, but it isnt climbing any higher even after driving for hours. My new trans is bypassed into a hayden cooler but i plan on installing this huge one I just bought to try to bring it down more, after that I will throw a fan on it. I'm running a mild stall with built trans and 4.56s so rpms are up there, and these temps are from the dash guage so I know actual temps maybe a little different.
flatblack83
Oct 8, 2015 08:29 AM
GRRR65GTO
Aug 17, 2015 11:33 PM
Ls3silverado
Jul 31, 2015 04:22 PM
dantheman1540
Jul 29, 2015 04:45 PM
