Converter issuse
Old May 12, 2006 | 09:58 AM
white1's Avatar
Default Converter issuse
I have two issues with my truck. One could possibly be related to the other, and Im stumped.
I have a 2000 silverado z71 with a LQ4 small cam (223/226) most bolt ons a Fuddle 3200 converter FLT level 5 tranny and 3.73's.
One issue is that my converter seems to flash to about 5200 not 3200, it has gotten a little tighter, but still seems high. To get the flash stall (Im thinking this is how, just double checking) you let the truck idle and hammer the gas and see where it starts to pull correct? Well this ends up in a small smoke show most times, so whats another way to check flash stall?
Also last week I borrowed a buddies N2O. Im spraying a 125 shot, but it feels like about 20, and only netted me .20 in the 1/4. While Im going down the interstate if I spray it my tach only picks yp about 200 RPM, and it just doesnt pull hard at all. Is there anyway (besides locking the converter in 2nd) to see if the converter is soaking up the hit, or if something else is wrong?
Thanks for the help guys.
Old May 12, 2006 | 11:55 AM
Quik's Avatar
5 year bitches!
too large of a stall will hurt you badly
on spray stalls usually rise about 500 to 600 more rpms
also depending on how you had the juice setup can effect how it performs
Old May 12, 2006 | 12:02 PM
white1's Avatar
I dont think 3200 is too big, do you? I know its flashing higher, but before I start chewing *** Id like to see what else it could be.
Also, Im spraying into the intake tube.
Old May 12, 2006 | 12:05 PM
Quik's Avatar
5 year bitches!
you said its flashing to 5200 correct? well if so thats way to high
mine is sprayed into air tube
Old May 12, 2006 | 12:14 PM
white1's Avatar
I see what youre saying now. YEa its flashing high, but it should still hit hard after that correct?
Old May 12, 2006 | 12:15 PM
Quik's Avatar
5 year bitches!
NO,
stalls should be in the torque range and i doubt you make torque that high and if your spraying now thats 5700rpms when it hits
send converter back
Old May 12, 2006 | 12:33 PM
goshawk23's Avatar
Truck addict
on spray my fuddle converter will hit ~3800 rpms... thats spraying off the line with good traction. if yours is going up to 5200 then something is not right. did you get the truck converter or the car converter.
Old May 12, 2006 | 12:44 PM
white1's Avatar
HP truck converter. Im gonna take a ride in yours tonight if you dont mind, then haul you around in mine so you can see what its doing. I dont know how I can afford for the truck to be down for who knows how long to get it re-stalled.
Old May 12, 2006 | 12:57 PM
99LoweredSierra's Avatar
Hope you get this one figured out White 1 something is sure not right
Old May 12, 2006 | 01:01 PM
TouchOfEvil04's Avatar
I rode in his truck last night and it definetly makes a good smoke show....4 wheels drive spun the front tires all through first and a mean second as well as a little distance into second...Matt i'm almost thinking its falshin a little lower than 5200 but when it grabs your spinning so hard it continues to fly up to 5200...but i only rode in it for about 10 mins so its hard to say really.
Then again you did brake stall it to 4 grand so yea its prob getting to 5k are higher...
