Clunk when moving starting from a stop
Old Feb 9, 2006 | 06:06 PM
Keith's Avatar
Default Clunk when moving starting from a stop
Recently my truck has developed a soft clunk when moving out from a stop. It feels like there is some driveline slop being taken up. I got down under the truck and tried to rotate the driveshaft. No freeplay there. I heard a while back about something with a slip yoke problem, but thought that was for the 4X4 guys.
But...
The carrier bearing rubber support seems to move around a little bit. Would it seem logical that the rubber support is letting the driveshaft "wrap up". And that is the clunk?
Any ideas?
Old Feb 9, 2006 | 07:35 PM
StrokerAce03's Avatar
Could be a little axle wrap. Have you modified the rear springs at all? Mine started doing it bad when I took the overload leaves out. If that isn't it try checking the u-bolts and make sure they're tightened to spec.
Old Feb 9, 2006 | 08:21 PM
COLDZ71's Avatar
Also check to see if the little pad is on the end of the short leaf spring. If it isnt, axle wrap will cause the springs to contact while taking off, causing a clunk sound.
Old Feb 9, 2006 | 08:25 PM
ASkipper's Avatar
11 Second Club
I had the same problem.If you will drop your driveshaft and put some good grease on the transmission splines.The clunck is actually the drive shaft catching on the splines.
Old Feb 9, 2006 | 09:23 PM
Keith's Avatar
My truck is stock. I'll take a look at the spring pads though, the u-bolts too.
I think this weekend I'll change my transmission fluid and filter. When that is going on I'll try the grease on the splines. I know I've heard about that before, just thought it was 4WD guys only.
Old Feb 10, 2006 | 10:05 AM
Zick's Avatar
My old 99' had this same problem. Took it to the dealership under warrenty and they replaced the slip yoke with the nickel coated version and it fixed it. I sold the truck before I got a chance to put more miles on it so I don't know if it would come back or not.
Old Feb 10, 2006 | 11:55 AM
Keith's Avatar
I wonder if they would touch my truck now. I have 43,xxx miles on it.
Old Feb 10, 2006 | 01:02 PM
Zick's Avatar
Depends if you still have warranty on it. Mine had about 93,000 miles and I had a extended warranty and was good to go.
Old Feb 10, 2006 | 11:12 PM
Keith's Avatar
I called the dealer today. Told a service writer what was going on. They seem up to at least telling me for sure if it is the slip yoke. Chevy might even take care of it. We'll see on monday.
Thanks for all the help.
treylittlefield
Jan 24, 2016 07:38 PM
Mossyoakglock
Aug 28, 2015 12:49 PM
Ferocity02
Aug 7, 2015 08:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
rojeho
Jul 12, 2015 06:10 PM
