circle d 3200.. To transgo or not to transgo?
Old Dec 30, 2010 | 06:25 PM
whitedakota's Avatar
Question circle d 3200.. To transgo or not to transgo?
i plan on putting a circle d 3200 in my crew cab in my sig in the next month or so. since im gonna pull the tranny do i need to do the transgo hd shift kit also? or just pull the pan and change the filter and fluid. i have a corvette servo, and some added line pressure via hp tuners. will i see a little longer life possibly putting a trans go in or is it not worth messing with?
thanks,
steve
Old Dec 30, 2010 | 06:36 PM
1slowz71's Avatar
due it and slap in there a 40k tranny cooler too, so you can extend your short tranny life! its way worth it
Old Dec 30, 2010 | 07:37 PM
Rhino79's Avatar
9 Second Club
Line pressure back to stock, do transgo, 0 out shift times, abuse mode off, tranny cooler, and you will be set.
Old Dec 30, 2010 | 07:40 PM
what is stock line pressure? i saved the factory tune, but then laptop crashed i lost everthing! yeah im gonna do a 40,000 tranny cooler also. its lasted 128,xxx hard miles this far and still shifts as good as day one! (knocking on wood as i typed!)
Old Dec 30, 2010 | 08:59 PM
Rhino79's Avatar
9 Second Club
It depends, if you didnt bump the pressure up much, you may be fine. Also watch how many shims you put in the accum.....I wouldn't do 2 unless you want your dash to break off on the 1-2 shift...lol I would go with 1 shim.
Old Dec 30, 2010 | 09:04 PM
black04's Avatar
Definitely do it. They are very easy to instal and cheap.
Old Dec 30, 2010 | 10:22 PM
devink's Avatar
how long does it take to install one of these kits? I'll be pulling my trans soon to add a stall converter but can't afford to have my truck out of commission for very long.
Old Dec 30, 2010 | 11:31 PM
black04's Avatar
They are really easy to do. I can do one in probably about 2 hours or less after dropping the pan. The hard part is removing the exhaust and getting the pan down but if you pull the trans out its a piece of cake.
Old Dec 31, 2010 | 01:01 AM
what do you guys reccommend setting it up shim wise if i pack the shift pressure down a little bit with hp tuners? still only 1 shim?
SloSVO
Nov 22, 2020 07:34 PM
madmann26
Apr 29, 2020 09:17 AM
Wolftrk99
Dec 3, 2015 08:12 PM
Wolftrk99
Oct 2, 2015 08:17 AM
sTNT971
Sep 26, 2015 06:27 AM
