circle d 3200.. To transgo or not to transgo?
i plan on putting a circle d 3200 in my crew cab in my sig in the next month or so. since im gonna pull the tranny do i need to do the transgo hd shift kit also? or just pull the pan and change the filter and fluid. i have a corvette servo, and some added line pressure via hp tuners. will i see a little longer life possibly putting a trans go in or is it not worth messing with?
thanks,
steve
thanks,
steve
what is stock line pressure? i saved the factory tune, but then laptop crashed i lost everthing! yeah im gonna do a 40,000 tranny cooler also. its lasted 128,xxx hard miles this far and still shifts as good as day one! (knocking on wood as i typed!)
It depends, if you didnt bump the pressure up much, you may be fine. Also watch how many shims you put in the accum.....I wouldn't do 2 unless you want your dash to break off on the 1-2 shift...lol I would go with 1 shim.
They are really easy to do. I can do one in probably about 2 hours or less after dropping the pan. The hard part is removing the exhaust and getting the pan down but if you pull the trans out its a piece of cake.
