Cam Gears Stall
Old Jan 5, 2005 | 11:24 AM
04BL53SLV's Avatar
Default Cam Gears Stall
Patience all you Guru's! I have an 04' ECSB 5.3 , w/3.42 gears. Question is whether to go with a stall first (Yank 3000) gears(3.73) or cam (Z06)?
Which order? What effect would the stall have by itself? Are the new gears even necessary? I was thinking about the cam because of all the things I have read here. Of course I would order custom tune lastly. Some input on this would be appreciated. Just being able to ask this question shows how much I have learned from this site! MY only mod is a Magnaflow Cat Back. Help me out fellows...
Old Jan 5, 2005 | 05:22 PM
KeukaZ71's Avatar
i would get a yank 3000 TC. see how you like that with your 3.42's. if that doesn't give you enough launch down low, you can swap 3.73's.
also, LT headers can give you some more power down low.
also, for more HP, try e-fans, CAI, and custom tune like you anticipate on getting.
Old Jan 7, 2005 | 06:17 PM
chris99gmc's Avatar
stall first.. then a tune.. then cam.. then re-tune.. then posi if you dont have it. and gears at the same time
Old Jan 7, 2005 | 09:41 PM
02sierraz71_5.3's Avatar
I would do the shift kit and servos while you do the stall, then get a tune and remove all torque managment, then you'll need new tires
LCHEE
Oct 24, 2020 04:10 PM
Castro45
24
Jul 31, 2015 07:13 PM
vmaxpro
Jul 27, 2015 10:45 PM
EscaTruck
Jul 20, 2015 11:42 AM
06 4.8
Jul 14, 2015 08:09 AM
