Turbo400 truck guys inside...
Old Jan 6, 2005 | 11:44 AM
GrannySShifting's Avatar
Default Turbo400 truck guys inside...
Any of you hook up your speedo/ Is the VSS signal for the trucks originally equipped with the 4L60E the same as the Fbody? If so no reason I cant use the same VSS, reluctor ring, splice into VSS harness that I use on the fbody is there? The output shaft is the same diameter at the VSS housing point to press fit the ring on correct?
Also, any way to remove the column shifter stalk without LOTS of hassle
Old Jan 6, 2005 | 12:37 PM
Flyer's Avatar
I'm not seeing the relation to a th400 trans here .. but the 60e in the trucks is the same as the one in the cars if that's what your asking.
Old Jan 6, 2005 | 02:29 PM
??? Im asking if T400 guys hooked up their speedo, and if they did did they do it like we do with the fbodies????
Old Jan 6, 2005 | 02:44 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
To the best of my recollection, there are NO guys around here running the TH400. Although I may be wrong, I think 2toneblown may have just switched to one. Maybe you could PM him.
Old Jan 6, 2005 | 02:58 PM
lm7's Avatar
lm7
texas term is running one, black sheep, c3c5, and most of the faster guys are running 400's
Old Jan 6, 2005 | 03:23 PM
2toneblown's Avatar
Mine is not hooked up to a speedo. I wish I could find an easy way to make it work though, I still am going to drive it on the street alot and knowing how fast Im going would be a plus
Old Jan 6, 2005 | 07:26 PM
vanillagorilla's Avatar
TCI makes a little computer that goes inline for cable driven speedos so you can hook them to electronic transmissions like the 60e and 80e. Its for retro-fits into older vehicles. Anyway I wonder if they make one or if you could run one backwards so it would convert an electronic signal to a cable so it could be hooked to the little gear in the 400. Also I know for the speedo to be accurate in older transmissions, you have to change the little gear according to your rear end ratio.
Old Jan 6, 2005 | 08:11 PM
desTRUCKtive's Avatar
But are you done with your truck!!
Old Jan 6, 2005 | 08:17 PM
blacksheep's Avatar
I have always run a 4l60e
Old Jan 6, 2005 | 11:08 PM
Flyer's Avatar
Texas terminator runs a th400, c3c5 runs a th350.
I would imagine it's all about the same.
