Bolts that came with the pinion angle shims?
Old Apr 11, 2012 | 09:54 PM
Ferocity02's Avatar
Default Bolts that came with the pinion angle shims?
I bought these pinion angle shims for my truck: DJM Suspension ACC-6PSK - DJM Suspension Pinion Angle Shims - Overview - SummitRacing.com
My current pinion angle is 3* with 2* shims. So replacing the 2* shims with these 6* shims should make the pinion angle -1*.
They came with the pictured bolts. I think they go through the leaf spring and hold together the leaves in the middle. But why did they send me them? Will the stock ones not work? The head of the bolt is not thick enough to protrude through the 6* shims anyways.
I was going to install them tomorrow. Thanks!
Old Apr 11, 2012 | 11:20 PM
sprayedenali's Avatar
you have to have something going through the shim into the spring perch on the axel.... its what keeps the axel in place on the springs
Old Apr 11, 2012 | 11:24 PM
iamkeniff's Avatar
^^^ yep. The stock bolt doesnt have a long enough stud for the shim and rearend to connect to
Old Apr 11, 2012 | 11:44 PM
Ferocity02's Avatar
Ok but the head of the bolts that came with shims isnt even long enough to go through the shims.
Old Apr 12, 2012 | 01:36 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Add the little spacer shim at the head of that bolt, and then the head will be able to reach all the way through the shim and into the axle perch. I see the spacer shims in the pic, just above the nuts.
Old Apr 12, 2012 | 10:13 AM
Ferocity02's Avatar
Ah yes! For some reason I thought the spacer went on top of the spring under the nut. Sweet, hopefully these do the trick.
Old Apr 12, 2012 | 08:43 PM
Ferocity02's Avatar
Got them in today, and phew, glad I did! With the 2* shims that were in there, the head of the bolt wasn't sticking through far enough. They were resting on top of the spring perch about 1/8" from being in the hole. The longer pins worked out, but they could still be 1/4" longer or more. It was still tricky getting them seated in the holes with confidence.
Seems a bit smoother on the highway now. Can't say if I gained any traction though.
Old Apr 13, 2012 | 12:52 AM
PM me your mailing address, and I'll send you 2 more spacers in the mail. That should do the trick.
Old Apr 13, 2012 | 01:39 AM
Ferocity02's Avatar
Thanks for the offer, but I won't be messing with them again for awhile, I hope. The hardware store has the spacers too.
BCraven1018
37
Dec 20, 2016 11:46 AM
GXPJAY
Nov 5, 2015 06:49 AM
mhotrodscooter
Aug 23, 2015 04:41 PM
1bad2k
Aug 18, 2015 09:50 PM
121
Jul 16, 2015 12:18 AM
