Body Lift Install - Help
Old Dec 15, 2006 | 08:17 AM
kelchie's Avatar
Default Body Lift Install - Help
Hi, I want to get a 3 inch body lift for my truck. Im guessing i dont have whatit take to lift the body and install the spacers so what im asking is how many hours labour it would be at a shop or an approx. cost to install a body lift.
Thanks
Korey
Old Dec 15, 2006 | 10:39 AM
KY_BOB's Avatar
Figure on about 8-10 hours of labor at whatever your shop charges per hour.
I've helped do a couple on Avalanches. It's not hard just time consuming. There is a little metal cutting that can be done with a torch or a sawzall. Other than that, you just need basic hand tools, time, and a extra pair of hands helps.
Old Dec 15, 2006 | 09:50 PM
munchman's Avatar
i can put a body lift on a nbs chevy or gmc in about 5 hours but most shops charge for 8 hours of labor around here
Old Dec 15, 2006 | 09:57 PM
gao8302's Avatar
To lift the body from the truck all you need is a jack and a piece of wood. Everything else is basic metric wrenches. Do it yourself its easy just get a buddy for an extra hand. Your basic everyday do it yourselfer can do this. Very easy. If you run into problems just pm me i have installed many body lifts. Save your money for the next mod.
Old Dec 17, 2006 | 04:05 PM
UB2SLO's Avatar
I did mine all by myself and it took me around 7 hours. I didn't have anyone to help with moving the bed and cap around while I was trying to line up the bolts, if I did it would have saved time. And the front bumper was a bitch other than that it was ok.
Old Dec 17, 2006 | 08:05 PM
kelchie's Avatar
Do the kits come with a good clear set of instructions. Im leaning toward doing it myself now. So ill need a jack or 2 and some blocks of wood, some wrenchs and a helper and i should be all set? Thanks for the help guys.
Old Dec 17, 2006 | 08:41 PM
tenshikurai's Avatar
I'd say do it yourself if you've got decent hand tools and a good jack. Mine took me about 8 hours, but a lot of that was building new bumper brackets for my custom front bumper, and a little alteration for the roll pan in the back.
Old Dec 17, 2006 | 10:16 PM
kelchie's Avatar
for the cab do you just un bolt everything, jack up one side, put the spacers in then do the other side?
Old Dec 21, 2006 | 12:15 AM
chewybravo's Avatar
IMO, a body lift is totally not worth it, you should just get a suspension lift, it would look so much better.
but if u decide to put the 3'' body lift on , the labor should only take a half a day at most if u do it urself
thunder550
Oct 8, 2015 04:53 PM
Kaldar
Jul 27, 2015 06:42 PM
Slammed96
Jul 27, 2015 07:22 AM
08nali
Jul 23, 2015 11:39 PM
