Is this a bent axle flange?? video
Old Jun 30, 2014 | 02:49 PM
BIGDADDY1969's Avatar
Question Is this a bent axle flange?? video
Check video .. drivers side hardly any wobble... passenger side wobbles ... whole truck wobbles like rear end hopping up n down at 45 and 65 .. in between those speeds hardly anything at all ... just put new rims and tires my old rims were bent also.. i have swapped other rims and tires to be sure it still wasnt my new ones but this wobble in the video is present no matter what ... im pretty sure on the bent flange... question is do i get new shafts or swap whole rear end..
video of wheel wobble - YouTube
Old Jun 30, 2014 | 04:06 PM
ecir45's Avatar
The flange only holds brakes on, our rears have a c-clip holding axle. I'm guessing but could be bent axle, bad bearing or bent axle tube where it meets the center section. Look under the truck to eyeball the tube where it meets the center section. Pulling the axle should show the problem after inspection.
Old Jun 30, 2014 | 06:40 PM
No the axle shaft has a flange on the end(its one complete machined piece) with the six lugs on it that the tire bolts to and also the brake drum slides onto.. The brakes shoes are mounted to a different flange connected to the rear end housing itself .. 2 diff flanges ...
Old Jun 30, 2014 | 06:43 PM
I already knew theres a flamge on the end of the axle shaft .. Was just wondering if anyone had this issue before .. Im going to change axle shaft .. All things point to the wobble being the axle shaft flange after i showed a few people the video
Old Jun 30, 2014 | 08:29 PM
ecir45's Avatar
Sorry for the misunderstanding of your description. Never seen one bent there before, let us know what you find. Maybe take a video with the brakes removed exposing just the axle.
Old Jul 1, 2014 | 03:45 AM
NP man .. Been a long week last week tryin fig this thing out.. Im try take wheel off n watch the bate flange but im gunna havve a new one by the time i do that and im just gunna tear it out and put new one.. Will post results as soon as i get er dome!
Old Jul 1, 2014 | 05:31 AM
Chevy_King1500's Avatar
swap wheels from one side to another.
Old Jul 1, 2014 | 02:25 PM
Unhappy
"i have swapped other rims and tires to be sure it still wasnt my new ones but this wobble in the video is present no matter what" ... Done that ...
bearden86
26
Nov 15, 2015 03:58 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
twake_410
Sep 25, 2015 10:09 PM
