Belltech shackle adjustable?
Old Aug 29, 2005 | 06:32 AM
agreif's Avatar
Default Belltech shackle adjustable?
I remember people talking about that but when I went to install the shackle 1 bolt hole down from the full "2" drop the flange was in the way. Do people trim that flange to change the drop from left to right?
Thanks,
Andrew
Old Aug 29, 2005 | 08:22 AM
Mort's Avatar
Cool
I had mine adjusted 1 hole different side to side for a while. I am not sure what you mean by the flange being in the way. You should not have to trim anything. Maybe just flip the shackle 180* so the flange (?) is no longer in the way.
Old Aug 29, 2005 | 08:39 AM
agreif's Avatar
Yeah, I'm an idiot. I originally installed the shackle backwards (shackle plat facing forwards) and it wouldn't adjust. Then I realized that I had it backwards and flipped in to the correct orientation and didn't check again. Duh. Sorry for the stupid question and thanks for the response to jog me out of the idiot cloud I was stuck in.
Andrew
Old Aug 29, 2005 | 09:26 AM
LVSTOGOFST2002's Avatar
i trimmed mine so it would fit......... maybe mine wasn't adjustable to begin with? and i didnt' install it backwards, so i know it's not that.
Old Aug 29, 2005 | 11:57 AM
agreif's Avatar
trimmed the plate?
Old Aug 30, 2005 | 08:01 PM
duwem's Avatar
my stock ones had the plate aka the flat part of the "c" facing the front so thats how I did the Beltech, using the top hole thou, I would think you could use the next lower hole if you put the open side foreward??? I didnt have instructions so I wouldnt know what Beltech says.
Old Aug 30, 2005 | 08:04 PM
agreif's Avatar
Yeah, belltech instructions show the "open" part facing forward, so the plate is at the rear of the truck. Haven't gotten back down there to look.
Old Aug 30, 2005 | 10:40 PM
i trimmed the shackle on the back side a lil to clear the eye of the spring. i didn't want it to bind.
Old Aug 31, 2005 | 06:41 AM
JimS's Avatar
I had to trim mine or the spring eye hit the back of the shackle. Took off about 1/2 inch.
BCraven1018
Nov 2, 2015 07:18 AM
MikeD.
Oct 13, 2015 08:08 AM
Alco
Oct 4, 2015 06:58 AM
01silvy
Sep 26, 2015 10:20 PM
97_ek
Sep 23, 2015 09:16 PM
