any way to add back an inch after usning flip kit?
Old Aug 13, 2010 | 08:44 PM
bentrek's Avatar
Default any way to add back an inch after usning flip kit?
I was hoping for a 1" lift leaf spring....but it seems as though they are unnecessary since most people use spacers when the rear end is on the "right" side of the springs.
Old Aug 13, 2010 | 08:48 PM
Krazy Ken's Avatar
I added a leaf from another half ton set and it raised my back in close to 2 1/2 inches so i ended up putting smaller blocks in the rear. I actually think it handles better with the stiffer spring and i don't notice a ride quality difference than my buddies identical truck other than i have less body lean.
Old Aug 13, 2010 | 09:05 PM
KleenHall's Avatar
adding a leaf will help some but will change the ride too
what shackles do you have?
Old Aug 13, 2010 | 09:21 PM
Krazy Ken's Avatar
Are you asking me?
Old Aug 13, 2010 | 09:24 PM
bentrek's Avatar
Stock
Old Aug 13, 2010 | 09:47 PM
dlt76028's Avatar
adding a leaf to a truck with a flip kit will LOWER it more.
Old Aug 13, 2010 | 09:57 PM
Camaro Zach's Avatar
you can get a 1" lift shackle or you can get a new rear hanger that flips the shackle over and moves the axle down an inch. I made a set of hangers for mine to lift the back 1 inch.
Old Aug 13, 2010 | 10:37 PM
00ChevyScott's Avatar
Wearin' da big hat
I was thinking the same thing. Some people just don't read.
Old Aug 14, 2010 | 01:23 AM
KleenHall's Avatar
whaaaaaat???
no it wont, even if the spring runs under the axle it gains height from the added force of the new leaf
if adding a leaf gets too much height you can adjust with the shackle length
Old Aug 14, 2010 | 09:17 AM
Wearin' da big hat
The thickness of the leaf pushes the axle up more, and drops the body more. It might stiffen up the leafs a little bit but I'd say it'd drop it more.
