aftermarket rotors
#44
ok, i did some digging and found part numbers for some of the power slot rotors, they are Power Slot 8657PSL and Power Slot 8657PSR and are the 13 inch diameter rotors buybrakes . com even lists them as for models with rear drums. and they are about 120 a piece. thanks d reks!
#46
Drilled rotors are for bling, if you use them for repeated heavy duty stops you can cause hair line cracks. Slotted rotors may help, especially if you run HPDE in a vette. For every day driving and towing modern rotors and brake pads will do. Slotted rotors were used in the 70-80's extensively in racing, today you very seldom see them--look at the C6R Corvette. You are better off getting stock rotors and running Hawke HD truck pads or something similar. I tow an enclosed trailer (24' and corvette inside) and use that set up. On the vette I use stock NAPA rotors and racing pads. HTH
#47
#49
06, 8657psl, 99, aftermarket, calipers, calspeedandperformancecom, epoxy, g2, powerslot, rotars, rotors, silverado, ss, trailblazer, tsp
