Adjusting Caltracs
Old May 20, 2009 | 01:36 AM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Default Adjusting Caltracs
just wonderin how you guys on here adjust your Caltracs they say to snug them on the leaf spring and then do a 1/4 turn then snug the bolts
Old May 20, 2009 | 05:37 AM
CurtD's Avatar
10 Second Truck Club
Thats it...when I adjusted mine like that I could leave with no tire spin!!
Old May 20, 2009 | 12:15 PM
sweet thanks
Old May 20, 2009 | 01:19 PM
shakesvho's Avatar
I have them set this way for the street works well and rides nice, I do play with the adj now and then and with street tires I found setting the bar to the top hole and give it a good few turns it hooks good, but rides like crap
Old May 20, 2009 | 01:29 PM
Dark Halo's Avatar
I noticed when I took out my overloads the caltracs did not allow any drop do I need to re adjust?
Old May 20, 2009 | 01:38 PM
vanillagorilla's Avatar
Make sure you adjust them with you or some one who weighs similar to what you do in the driver's seat. It will launch straighter that way assuming it hooks.
Old May 20, 2009 | 04:00 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Old May 20, 2009 | 05:32 PM
i have to try this when i go to the track
didnt know that ill make sure that i do that thanks
Old May 20, 2009 | 05:53 PM
fossil's Avatar
11 Second Club
Same thing here with overloads off, rear does not drop much. I back off 1 whole turn on my caltracs. I do have a 4 degree shim, so my pinion angle still is negative. Mine hooks on any track surface with mine adjusted this way.
Old May 20, 2009 | 07:22 PM
so in other words, put Mr. Travelocity in the drivers seat, should be close enough
