A4 to A3 Swap guys in here!
Old Feb 22, 2007 | 06:12 PM
Dirty 30's Avatar
LS1Tech Whore
Default A4 to A3 Swap guys in here!
Any good info or pics perhaps even a write up on this??? I have an 03 Reg Cab Silverado with an LS1 and the truck 4l60e. I want to convert to a TH350. Thanks in advance.
Old Feb 22, 2007 | 06:21 PM
Zick's Avatar
One question....Why?
Old Feb 22, 2007 | 06:24 PM
bluecajun5.3's Avatar
11 Second Truck Club
one question, why?
Old Feb 22, 2007 | 07:54 PM
jasond26's Avatar
I am putting a rossler th400 in this weekend, I will let you know how it goes.
Old Feb 22, 2007 | 08:33 PM
vanillagorilla's Avatar
I plan doing a write up for this like I did for the T56 swap when I do my TH400.
AFAIK, you'll need an SFI flexplate with a spacer so you can use an off the shelf TH350/400 converter. You'll need to modify your crossmember. You can get a reluctor ring installed on the tailshaft so you can use a VSS out of a late 80's early 90's OBS truck. All you'll need to do then is change the tooth count in your tune. You'll need a shifter/cable and dip stick. You'll probably need to modify your driveshaft too which will be a good time to upgrade to some 1350 u-joints.
Old Feb 23, 2007 | 12:48 PM
Dirty 30's Avatar
LS1Tech Whore
Thanks!
Old Feb 23, 2007 | 12:53 PM
Dirty 30's Avatar
LS1Tech Whore
4l60e's suck, 4l80e's are too expensive.
Old Feb 23, 2007 | 01:34 PM
quicksilverado's Avatar
It is a 4l60 without overdrive.
Old Feb 23, 2007 | 07:43 PM
Quik's Avatar
5 year bitches!
you can have a 60built strong enough to holdup...no true reason in a street truck to go 350/400
Old Feb 23, 2007 | 09:47 PM
Zick's Avatar
Only thing I can think of, is that it's probably cheaper to build a TH350/400 to the same level of a built 4L60? Maybe I'm wrong though.
