99 Sierra 1500 5.3 4l60e problems
Old Oct 6, 2015 | 12:39 PM
truefire04's Avatar
im not sure, its a used truck, is there anyway to tell if its the stock trans?
Old Oct 6, 2015 | 12:47 PM
truefire04's Avatar
from looking at this site here
30 Common 4L60E Transmission Problems & Repair | Charlotte NC
its kinda like issue #3
but only when cold. once its warmed up its fine.
Old Oct 6, 2015 | 02:21 PM
Wolftrk99's Avatar
Seals hard on accumulator maybe??? When theyre cold it sticks or pins worn, stock i do remember that being a plastic piston. Pull pan and check the accumulator housing for wear... As well as the piston...
Old Oct 6, 2015 | 02:37 PM
truefire04's Avatar
do i have to drop the vb?
Old Oct 6, 2015 | 02:41 PM
Wolftrk99's Avatar
No just the accumulator housing that sits next to it....
Old Oct 6, 2015 | 02:44 PM
Wolftrk99's Avatar
This is what the underside looks like when you yake it off just hopefully not so much metal in the fluid...
Old Oct 6, 2015 | 02:46 PM
truefire04's Avatar
should i order any parts before i take it apart? just in case?
Old Oct 6, 2015 | 03:17 PM
truefire04's Avatar
so would i need these?
1-2 or 3-4 Accumulator Spring - 74926 - Sonnax
Pinless Accumulator Piston Kit - 77998-03K - Sonnax
Old Oct 6, 2015 | 03:22 PM
truefire04's Avatar
the only thing that leaves me puzzled is that it only does it if the transmission is cold.
Old Oct 6, 2015 | 04:08 PM
Wolftrk99's Avatar
Should be able to reuse the stock spring... Order from rockauto, got 2 of them shipped for less than what everyone else wanted for one before shipping...fluid has different thickness cold and warm...
