80e 4x4 swap transfer case question
Old Jan 17, 2010 | 05:36 PM
orange1500hd's Avatar
Default 80e 4x4 swap transfer case question
i read the sticky at the top about the input shaft swap on the t-case but if i bought a 4l80 with transfer case attached it would be drop in and i wouldn't have to re use my 4l60 transfer case, correct? from my research the 1500 and 2500's both use the np246 t-case. just wondering if theres any wiring difference or if im missing something.
Old Jan 18, 2010 | 10:18 PM
bohr898's Avatar
Restricted User
the 2500 could have either the auto trac 246 or like a 261 or maybe 241 i dunno.... butt easy way to tell.. is if its a floor shift transfer case then it def not a 246..... but to answer ur specific question yes they are wired the same way.... there is no diff between the 1500 and 2500 246 t-case besides the diff input shafts..... 27 spline for the 4l60... 32 spline for the 4l80 but im sure you knew that
Old Jan 20, 2010 | 01:16 AM
i have autotrac so its the 246 case. the reason i want to get a used 80e with transfer case is because i want to keep the stock 60e/transfer case untouched so if i want to back to stock it will be there ready. anyone done this?
Old Jan 20, 2010 | 07:40 AM
bohr898's Avatar
Restricted User
yes it has been done and it will work
Old Jan 20, 2010 | 11:43 PM
DrX's Avatar
DrX
I swapped in an 80E style 246 along with my 80E. Everything other than the input gear is the same except for the 6 pinion planetary assembly vs 3 or 4 pinion(depending on model year) for the 60E 246.
Old Jan 22, 2010 | 05:31 PM
sounds good, il probably do this before i get the turbo on.
Old Jan 25, 2010 | 04:22 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Are you talking about doing this to your 1500HD??
Old Mar 23, 2011 | 02:04 PM
sharpshooter's Avatar
are the front and rear output shafts the same on the 1500 246 and the 2500 246?
is there really advantage going to the 2500 246 besides I won't have to swap the input shaft?
Old Mar 28, 2011 | 07:59 PM
DrX's Avatar
DrX
I believe they are the same, but you will need a 2500 front DS anyway.
the 2500 246 has a 6 pinion planetary set vs 3 or 4 (depends on model year) in the 1500 246.
thunder550
Oct 8, 2015 04:53 PM
MileHighSierra
Jul 22, 2015 11:19 PM
04BlackGmc
Jul 16, 2015 04:10 PM
alex226
Jul 16, 2015 10:55 AM
Gadgetized
Jul 7, 2015 04:40 PM
