8.5 or 8.6...?
Old Feb 10, 2009 | 01:07 PM
buzzkillwill's Avatar
Default 8.5 or 8.6...?
I've got a 2004 2WD 1500, which size rear end is it?
I thought it was an 10-bolt 8.5 rear end.
Tried to buy something for it and was told it was an 8.6...??
EDIT: Nevermind, I got some good information by searching. Turns out GM changed in 2001 from an 8.5 to 8.6, but some parts are still universal, but some aren't...
Old Feb 10, 2009 | 01:56 PM
budhayes3's Avatar
PT's Slowest Truck
I thought that they changed in 99....(why do I think that I'm going to be buying to sets of bearings when I do my trutrac darn it!)
Old Feb 10, 2009 | 06:11 PM
blackbeast ss's Avatar
you have a 8.625" rear end
Old Feb 10, 2009 | 06:56 PM
You might be right... After re-reading, might be 2000, I'm not sure...lol
My concern was I bought a true-trac for an 8.5 rear and and 4.10 gears.
Then, went to get the install kit and was told it was 8.6, not 8.5- I got a lil' nervous.
Old Feb 10, 2009 | 07:32 PM
yep pre 99 is the old 10 bolt 8.5" rear
99+ is the newer 8.625" 10 bolt rear
Old Feb 10, 2009 | 10:06 PM
QLF's Avatar
QLF
Either way it shoulld fit. Only the ring gear diameter changed. Hence the 8.5" or 8.6" dimensions. IIRC, carriers and ring gear bolt pattern are the same.
Old Feb 10, 2009 | 10:57 PM
GMCtrk's Avatar
the install kit is different between th 8.5 and 8.6...i know because i ordered the 8.5 one and Ron emailed me telling me i need the 8.6
Old Feb 10, 2009 | 11:22 PM
QLF's Avatar
QLF
I was wrong apparently, the ring gear is the same size at 8.5" but the install kits are different just like GMCtrk said. 8.6 is always 30 spline and came on 99 and up trucks (NBS).
Old Feb 11, 2009 | 07:19 AM
Yep, Ron straightened me out, too.
Onetogofast
Jul 27, 2015 08:33 AM
2003Silvyrado
Mar 18, 2004 12:01 AM
OUT2WIN
Aug 31, 2003 12:56 PM
oxidizr
23
May 14, 2002 06:04 PM
