Trans or Converter? ... Help analizing scan...
Old Feb 9, 2009 | 12:57 PM
BigKID's Avatar
Default Trans or Converter? ... Help analizing scan...
I have been having some slipping with my 4L80 so I ran a scan to determine if it is the trans, converter or both. Once I started analyzing the scan, I saw a few things that bewildered me such as the input and output rpm staying the same in 4th (although I can clearly feel it shift to 4th when driving) and i/o rpm higher than engine rpm in 4th with converter locked. If you guys could look over the scan and provide your input I would appreciate it. Starting at 22:47 I used the controls to lock the trans in 3rd and lock the converter (although the TCC mode says OFF).
Sorry, Site won't let me attach the config file.
File Type: hpl
Old Feb 11, 2009 | 08:03 AM
BigKID's Avatar
Can anyone tell me why I would be seeing a 1:1 input:output ratio in 4th or why the input rpm is higher than engine rpm on constant speed with the converter locked?
Old Feb 11, 2009 | 08:12 AM
KySilverado's Avatar
I meant to look at the scan when I was home with HPT..... forgot. I'll try tonight.
TAPyvehc93
Jul 23, 2017 10:54 PM
bighouse
Sep 27, 2015 12:37 AM
Blackrat48
Aug 16, 2015 11:56 AM
KyleW707
Jul 29, 2015 08:17 AM
Deceptarado
Jul 8, 2015 05:24 PM
