4l80e for sled pulling truck
Old Sep 29, 2013 | 06:52 PM
black4x4's Avatar
Default 4l80e for sled pulling truck
I'm looking to swap a 4L80e into my truck i use for sled pulling and was trying to decided how much it needs beefed up. currently I have a mild 5.3 in it maybe making 350-375 flywheel hp. So I figured shift kit, bw clutches, 34 element sprag, and maybe a billet input not sure if I need that or not. truck weighs 6500 lbs. also may try to pick up another 50hp over the winter.
Old Sep 29, 2013 | 07:21 PM
03sierraslt's Avatar
I can't see you needing a billet input shaft at that power level. If you are gonna have it apart then do the dual feed mod, get a good heavy duty cooler to keep temps in check. The other mods you listed sound good. I am sure some of the experts will chime in. I am happy with my BW clutches in mine.
Old Sep 29, 2013 | 09:28 PM
Vortec350ss's Avatar
You sled pull with a 1500 5.3? Wild. Have any pics of the truck?
Old Sep 30, 2013 | 06:17 AM
dirt track racer 81's Avatar
I'm making 700+ to the tire on a bone stock 4l80e.. Just now put a shift kit in it.. I'd say you'd be fine with just a shift kit.
Old Sep 30, 2013 | 06:32 AM
bud8fan's Avatar
why not just go with a TH400 if its just made for pulling
Old Sep 30, 2013 | 06:36 AM
Three6GMC's Avatar
X2? Is it built for a specific class or something because I thought sled pulling trucks pull some crazy weight and made more power the 375?
Old Sep 30, 2013 | 07:17 AM
black4x4's Avatar
Street stock class slot of places you have to run stock manifolds its a real limited class.
I want to keep over drive is why no th400
Old Sep 30, 2013 | 11:51 AM
Three6GMC's Avatar
Ahh ok I know nothing about that sport is why I asked. All I have ever seen is diesels with huge amounts of torque and heavy sleds on TV so when you said 375hp and a 1500 truck it threw me off.
Old Oct 4, 2013 | 02:00 PM
00gmc4.8's Avatar
Sled pulling is overrated.... Especially in NW Ohio everybody and there brother does it.. u should build a racetruck with what you have not a pulling truck. If you want a pulling truck buy a duramax like everybody else imo. A stock 80e should be suffice, but i would run the 60e till she blows you will break other parts before the trans though. worry about other modifications first before a transmission.
Old Oct 4, 2013 | 02:15 PM
silverado6.2's Avatar
Wow what a pile of useless info. I'm sure if he was into race trucks he wouldn't be pulling a sled. I'm also confident that he is pulling in the stock GAS class so a d-max wouldn't be allowed.
Anyway OP, a healthy 80e bone stock will be fine for what your doing. I see a lot of guys manually locking the converter once they get the sled moving and swear it helps.
