4l80e no workie----Trans or converter?
Swapped in a used 80e and all was fine. For about a mile. Didn't whine, changed out fine, took all gears.
Cut the truck off, started it back up and it won't move in any gear. Took a line off and the is no pressure
If I had damaged the pump installing the converter, would it have moved at all? Could it be the converter (it's new).
Its throwing a p1810 code, nothing else.
What do you guys think?
Pulled the pan and everything looked fine. Blake, Chevroletalltheway, installed a Sonnax boost valve for me and said everything he saw looked good as well. He runs a trans shop.
Would a bad sensor cause 0 pressure? Or is 0 pressure causing the code?
Looks like you have a range of possibilities:
Circuit Description with 4L80-E / 4L85-E Automatic Transmission
The automatic transmission fluid pressure (TFP) manual valve position switch consists of five normally-open pressure switches. The powertrain control module (PCM) supplies battery voltage to each range signal. By grounding one or more of these circuits through various combinations of the pressure switches, the PCM detects what manual valve position has been selected, and compares the actual voltage combination of the switches to a TFP manual valve position switch combination table stored in memory.
The TFP manual valve position switch assembly cannot distinguish between PARK and NEUTRAL because the monitored valve body pressures are identical in both cases. With the ignition ON and the engine OFF, D2 is indicated. When the transmission 20-way connector is disconnected, the ground potential for the three range signals to the PCM is removed, and with the ignition ON, D2 is indicated.
If the PCM detects an invalid state of the TFP manual valve position switch circuit by deciphering the TFP manual valve position switch inputs, then DTC P1810 sets. DTC P1810 is a type C DTC. For California emissions vehicles and vehicles under 8,600 GVW, DTC P1810 is a type B DTC.
Conditions for Running the DTC
DTC P1810 sets on the first occurrence in which any of the following condition occurs:
Condition 1
The PCM detects an illegal TFP manual valve position switch state for 60 seconds.
Condition 2
- No AT VSS DTCs P0502 or P0503.
- No AT ISS DTCs P0716 or P0717.
- No PSA DTC P1810.
- No MAP DTCs P0106, P0107 or P0108.
- No MAF sensor DTCs P0101, P0102, or P0103.
- No 1-2 SS DTCs P0751, P0752 or P0753.
- No 2-3 SS DTCs P0756, P0757 or P0758.
- No TP sensor DTCs P0121, P0122 or P0123.
- The system voltage is 6.5 - 18 volts .
- The engine speed is greater than 400 RPM for 7 seconds.
- The engine torque must be between 108 Nm (80 ft. lbs.) .
- 6.0L: 542 Nm (400 ft. lbs.)
- 8.1L: 881 Nm (650 ft. lbs.)
Condition 1
Condition 2
- The engine speed is less than 50 RPM for 0.3 second; then 50-525 RPM for 0.025 second; then the engine speed is greater than 525 RPM.
- The vehicle speed is less than 8 km/h (5 mph) .
- Engine RPM sequence must occur within 30 seconds of key on.
- The PCM detects the gear range D1, D2 or REVERSE before and after start up.
- All conditions are met for 7 seconds and AT ISS is greater than 200 RPM.
- The vehicle speed is greater than 8 km/h (5 mph) .
- The throttle angle is greater than 10 percent.
- The PCM detects an invalid state of the TFP sensor or the TFP circuit. The TFP switch indicates the following:
- P/N when the ratio indicates third or fourth gear for greater than 15 seconds.
- Reverse when the ratio indicates D4, D3, D2, and D1 for greater than 15 seconds.
- D4, D3, D2, and D1 when the ratio indicates reverse for greater than 7 seconds.
- For California emission equipped vehicles, the PCM illuminates the malfunction indicator lamp (MIL) during the second consecutive trip in, which the Conditions for Setting the DTC are met. For Federal emission equipped vehicles, the MIL is not illuminated.
- The PCM commands maximum line pressure.
- The PCM assumes D4 for the PRNDL shift pattern.
- The PCM freezes shift adapts.
- The PCM forces the TCC on in fourth gear.
- The PCM records the operating conditions when the Conditions for Setting the DTC are met. The PCM stores this information as Freeze Frame, California only, and Failure Records, California and Federal.
- The PCM stores the DTC P1810 in PCM history during the second consecutive trip, California, or the first trip, Federal, in which the Conditions for Setting the DTC are met.
- For California emissions, the PCM turns OFF the MIL during the third consecutive trip in, which the diagnostic test runs and passes.
- A scan tool can clear the MIL/DTC.
- For California emissions, the PCM clears the DTC from PCM history if the vehicle completes 40 warm-up cycles without an emission related diagnostic fault occurring.
- For Federal emissions, the PCM clears the DTC from PCM history if the vehicle completes 40 warm-up cycles without a non-emission related diagnostic fault occurring.
- The PCM cancels the DTC default actions when the fault no longer exists and the ignition switch is OFF long enough in order to power down the PCM.
- Refer to the Transmission Fluid Pressure (TFP) Manual Valve Position Switch Logic for the normal range signals and the illegal combinations.
- DTC P1810 can set from low pump pressure, a stuck pressure regulator, or unit fill from overhaul and pan removal.
- DTC P1810 can set by a slipping forward clutch. It may allow the PCM to see a 2.08:1 ratio, reverse, when the manual valve position is indicated as D4.
- DTC P1810 defaults to an elevated line pressure condition, which may result in partial TCC apply. This may produce an idle surge that could stall the engine.
That's a long description to not really say what causes it. ha
I unplugged all the connectors to eliminate wiring issues since it should default to 2nd gear, but still nothing
Thats not a typed out description its a copy and paste for your troubleshooting. There is no for sure way to know with the info that is given so far. I know some of those sensors were known to have issues but the fact that you unplugged it and had no second gear and the fact that you had no fluid flow out of the ports leads me to suspect the pump. I am no trans expert though.
Also, how was the fluid level? You can't trust the factory dipstick. The ideal fluid level (even with the case/trans pan interface) on mine was about 2" from the end of the dipstick, which is significantly above the top end of the hot mark on the dipstick.
