4l80E No Reverse, help!
Old Feb 19, 2007 | 11:29 AM
Stoichiometric's Avatar
Default 4l80E No Reverse, help!
I recently got my truck back together after pulling the engine/trans out for upgrades. The truck is a 2005 2500HD. I swapped the new 2005 80e out for a 2002 80e that I put a shift kit in. The truck runs and has forward gears but will not engage reverse. It free revs with the selector is in reverse. It is full of fluid and all connectors/linkage seem to be hooked up correctly. The tranny was supposed to be in complete running condition after being removed from a rollover truck.
Does it sound like I made a mistake somewhere putting in the shift kit? Any other input or things to check would help out a ton!
Thanks,
Henry
Old Feb 19, 2007 | 11:58 AM
I did some searching and found a few places to check. Sorry for the repeat post .
Old Feb 19, 2007 | 01:30 PM
I pulled the accumulator and didn't see any obvious problems. I read about a pin that can crack, does anyone have a picture or can describe where it is? I want to check whatever I can before I pull the trans back out of the truck. I have a feeling that the 4th/rev band is broken.
Old Feb 19, 2007 | 10:14 PM
I pulled the tranny back out. I am now looking for a complete rebuild kit and a good 4l80e shop manual. Anyone have any input on the manual for the 80e?
Old Feb 20, 2007 | 07:49 PM
TURBO8's Avatar
You can buy the manual and a video on ebay for like $50.
Old Feb 20, 2007 | 08:49 PM
Scream's Avatar
MOOBIES Moderator
I had a shop install a Transgo in my 80-e, and after they butchered it I got it back with no reverse. There was a pressure issue inside the valvebody, so I had to get a new valvebody and shift kit and have them installed.
Best of luck man.
Old Feb 20, 2007 | 08:51 PM
kbracing96's Avatar
Check out the stickys on this page, some great info on the 60's and 80's and how they work.
http://forum.efilive.com/forumdisplay.php?f=60
Old Feb 20, 2007 | 09:54 PM
Thanks a lot guys! I *think* I got everything correct on the shift kit, but I will double check my work now that the tranny is out. Those stickys are awesome, Thanks KB.
Old Feb 20, 2007 | 10:53 PM
00BlueTA's Avatar
12 Second Club
This happened to me when I got my shift kit put in. The trans shop forgot to put in a small spacer plate underneth the valve body. All the gears shifted great except reverse. It would only move very slowly at very low RPM's (under 1300 rpm)and thin just slip. I took it back and they put the plate back in and replaced the valve body gasket. After that everything worked correctly.
Blwn99x
Mar 24, 2023 11:14 AM
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
RustyD
May 23, 2016 07:04 PM
jscherbs
Sep 30, 2015 07:54 AM
