4L80e... flexplate question
Old Mar 24, 2013 | 08:01 AM
Default 4L80e... flexplate question
I've done 2 4L80e swaps so far, one in my 99 RCSB 4.8 and one in my 2004 GTO with a built LQ4 and LS1 crank.
I'm getting ready to do a swap now in a Mustang with a 2003 LQ4. What freakin flexplate do I need for this thing? I've searched high and low and I can not find a definitive answer. Do I need a "LS1 to 4L80e" flexplate with the crank spacer??? Do I not need a crank spacer and need the dished plate like the TCI 399754? I'm so confused and I need to get this **** ordered.
From what I've found, I think it was only the EARLY LQ4s that had the extended crank and therefore those are the only ones that DON'T need the crank spacer. Since mine is a 2003 I think I DO need the spacer and then just any LS1 to 4L80e flexplate will work.
So basically if I order the following am I good to go?
Hughes Performance LS1 Flexplate Adapters HP3795
Hughes Performance Heavy-Duty Flexplates HP4004X-EBP
Can someone please clarify for me so I can order parts today?
Thanks!
Adam
Old Mar 24, 2013 | 08:18 AM
03sierraslt's Avatar
What converter are you going to use?
Old Mar 24, 2013 | 08:19 AM
Stock 4L80e converter for now. Not a "conversion" converter.
Old Mar 24, 2013 | 08:56 AM
TIM Z's Avatar
11 sec. Truck Mod
Only the iron headed LQ4s had the extended crank .
You just need a stock flex plate for a 2003 LQ4 /4L80e , shouldn't be hard at all to get .
I believe 02' and up flex plate from 6.0/80e will work for you.
Sad to hear its going in a mustang but that's the only way to make them fast .
Old Mar 24, 2013 | 09:13 AM
Gadgetized's Avatar
From everything i have gathered, if you have the stock flexplate, and stock converter you will need the crank spacer.
Old Mar 24, 2013 | 09:24 AM
TIM Z's Avatar
11 sec. Truck Mod
Yeah , if he gets the stock flex plate setup for the 03 6.0/80e combo he will be set . I sold the stock flex plate I had from my 03 LQ4 but IIRC it had the spacer on the flex plate . Please correct me if I'm wrong it's been a while since I've seen it .
Old Mar 24, 2013 | 10:17 AM
I want an SFI approved one
Old Mar 24, 2013 | 05:02 PM
anyone? I want to order tonight.
Old Mar 24, 2013 | 06:04 PM
Get a 80e flexplate like a TCI, they come with the spacer.
Old Mar 24, 2013 | 06:29 PM
Circle-D's Avatar
Former Vendor
TCI 399754 is the SFI plate you are looking for. It does not need the crank spacer, the flexplate has it built in. You will need a converter pilot extender, and I think it comes with the TCI flexplate.
Chris
