4L60E to work manually
Old Nov 27, 2010 | 02:24 PM
MFSTERLING's Avatar
Registered User
Default 4L60E to work manually
Ive got an 06 silveraldo 1500 that I am wanting to do an engine swap in and
instead of spending the high amount of money on a trans programer, I was wondering if you could just put a manual valve body in and it would work. I would rather do that instead of having to reprogram the trans every time I do a power upgrade on the engine. Just wondering what my options are?
Thanks
Old Nov 28, 2010 | 07:16 AM
silver-mod-o's Avatar
Hunt&Fisherator
Putting a manual valve body on a trans will not magically increase it's power holding capability... You need to go into it, build it once (or buy a well built unit) and keep it auto. Manually shifting an auto that's not intended for it doesn't do it any favors, if anything it will damage it further.
Old Nov 28, 2010 | 07:20 AM
budhayes3's Avatar
PT's Slowest Truck
+1...at the very least just do a shift kit and some servos, but as your power level increases the likelyhood of your trans living decreases. Best bet is to have the unit built before it breaks (like mine did). I recommend contacting FLT or Performabuilt (links to right>>>), unless you know a local builder with a sterling reputation that you ultimately trust.
Jakejack
Jan 8, 2024 10:44 PM
Oobray
Jun 13, 2022 03:38 AM
XL7
May 5, 2022 01:48 PM
shawn96gmc
May 17, 2016 04:15 PM
dantheman1540
Jul 24, 2015 01:50 AM
