4l60e rebuild difficulty?
Old May 8, 2013 | 08:32 PM
  #21
vipergtrdj's Avatar
Originally Posted by 02 BLK WS6
Don't waste your money on 5 pinion plantaries. If you won't listen to me, make sure you get factory GM 5 pinion planetaries. The cheap after market chinese 5 pinion planetaries are weaker than the factory 4 pinion.
Make sure you get the borg warner 29 element dual cage sprag. I never liked the kevlar band. Install a new reverse input drum machined for a carbon wideband.
I am getting a factory GM planet gears, so that should be good. The dual cage sprag is also the borg warner 29 element as well.
I am really curious about the transmission problem I posted above, It sounds like a sensor but I don't know enough about them to figure out the issue.
Wolftrk99
Dec 3, 2015 08:12 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
gmcyukon
Oct 5, 2015 06:20 AM
Wolftrk99
Oct 2, 2015 08:17 AM
sTNT971
Sep 26, 2015 06:27 AM
