4L60E output shaft reluctor- swap?
Is the 4L60E relector not splined? ****... I bought one to go into my T56. Someone said it was a direct swap. Good thing it wasn't too expensive. If you need one I might be selling mine once it shows up
Make sure to put a thin layer of oil on the shaft when you press the new one on. This will help with it going on and keep it from binding and breaking. Don't ask me how I know this!
Also make sure that the reluctor is centered in the tail housing vss hole. This way you know that the sensor will read correctly. Good luck with the install.
Also make sure that the reluctor is centered in the tail housing vss hole. This way you know that the sensor will read correctly. Good luck with the install.Thread
GMCtrk
38
Aug 9, 2015 08:50 PM
Your welcome!!!
