4l60e build with $100 core...
Old Oct 7, 2015 | 04:21 PM
  #61
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Wolftrk99
Fedex showed up.... Yay!!!
Anything else yall think i should get...
A bigger wallet...
Back to work...
Perhaps a 4L80E...
Shall I keep going???
Old Oct 7, 2015 | 04:48 PM
  #62
tgui's Avatar
A bigger wallet...
Back to work...
Perhaps a 4L80E...
Yeah, 4l80e!
Old Oct 7, 2015 | 05:50 PM
  #63
Wolftrk99's Avatar
Speaking of which, i found a 4l80 out of an express on cl for $250....
Old Oct 7, 2015 | 07:27 PM
  #64
tgui's Avatar
Do it! Toss in the 4l60 and we can take time to build a 4l80 beast!!!!
Old Oct 7, 2015 | 09:01 PM
  #65
Wolftrk99's Avatar
Depends how long it takes to get money for my suburban and how much i can find 80e for ... Long story!!! The one on cl will probably be long gone by time i get the money... Thinking about building cores ive got and throwing em on cl, to try and recoop some of my funds... And maybe get money together for my cam??!!
Old Oct 7, 2015 | 10:34 PM
  #66
Wolftrk99's Avatar
Ummm, Sonnax forward and reverse abuse valves, yay or nay?? Thos would be the time to do them... Cant imagine a delco reman vb would have them installed
Old Oct 9, 2015 | 01:04 AM
  #67
Wolftrk99's Avatar
Got to the low/reverse sprag finally!!!
Glad i went back in after that!!! Was worse than i thought
Old Oct 9, 2015 | 01:12 AM
  #68
Wolftrk99's Avatar
And back together we go......
Replaced the rear planetary with the 4 pin
New sprag installed and lubed up
My tailshaft support tool
Front 4 pinion planetary
taken out
Front too!!!
Old Oct 9, 2015 | 01:22 AM
  #69
Wolftrk99's Avatar
And now for the input drum.....
Ready for transgo springs!!!
Spring installed
Old springs
Springs in!!!
Orifice plug out
Transgo in
My fancy ring sizer
Glad i remembered to grab these when i left work!!!
Snap ring in...
Over run and forward clutches in along with for sprag!!!
All done.... Went little tighter on clearance than recommended.... .035
Drum in.... I'll take my special sizer off tomorrow, or whenever i happen to get back over to work on it again....
Old Oct 9, 2015 | 01:30 AM
  #70
Wolftrk99's Avatar
And now for the pump..... And accumulator housing
Knocked pin out of 1-2 accumulator housing so i can clean it up at work and get the sonnax ***** driven into it....
Original valve...
Glad i pulled that!!!!
Pulled it all out!!! Wanted to make sure there was no more watery trans fluid in there!!!
New spring in
Sonnax purple pump spring
