4l60e build with $100 core...
Old Oct 9, 2015 | 09:39 PM
  #81
Wolftrk99's Avatar
That pic of 2-3 valve may have been OE coming out now that i think about it, that was about time i realized work was closing and had to pack it in.... Oops!!!
Old Oct 9, 2015 | 09:45 PM
  #82
Wolftrk99's Avatar
Originally Posted by truefire04
could you take pictures of the 1-2 accumulator after you put the ball in so i could learn from you and i will have a reference when i do mine.
also to, are you changing the servo? im going to install the vette servo when i receive my parts.
Seriosly, if you pick up a cheap punch set, which you'll find more uses for it than you could imagine, it makes installing the ***** a breeze mine took the smaller steel ball, and no spacer, if youre just getting the accumulator that's irrelevant information... Just reuse the OE springs unless you order the sonnax spring. As for staking the holes, all it is is disrupting the edge of the hole and creating a block for the ball to not get past, i ended up using a somewhat small roll pin punch that had been broken off and had a lip of sorts on it....
Last edited by Wolftrk99; Oct 9, 2015 at 09:46 PM. Reason: My illiterate thumbs took over again
Old Oct 10, 2015 | 10:14 AM
  #83
truefire04's Avatar
that worked, thanks Wolftrk99 i understand now, i have a few punches already i picked up from lowes or homedepot on sale. so there is two springs in the 1-2 accumulator, and no i just got the pinless accumulator piston kit for $9.99 and also the vette servo from amazon for $11.84 plus shipping just waiting on them now.
Old Oct 10, 2015 | 10:23 AM
  #84
Wolftrk99's Avatar
How much was shipping on the servo, got mine on amazon for 15.00 shipped
Old Oct 10, 2015 | 10:25 AM
  #85
Wolftrk99's Avatar
Actually 3 springs two in housing one below the piston against the plate
Old Oct 10, 2015 | 05:33 PM
  #86
truefire04's Avatar
i think total was 33 something, i picked up both the servo and accumulator piston.
Old Oct 10, 2015 | 06:19 PM
  #87
Wolftrk99's Avatar
Thats not too bad....rockauto has the piston cheper even with shipping than what amazon had em for but i also cme across a hella deal on the valve body too...
Old Oct 10, 2015 | 09:04 PM
  #88
truefire04's Avatar
i thought it was a good deal.
Old Oct 10, 2015 | 09:17 PM
  #89
Wolftrk99's Avatar
Considering ive found the pistons for as much as $18 and the srvo as much as 40something, youre fine...
Old Oct 11, 2015 | 07:46 AM
  #90
lt1z350's Avatar
damn had u dug a little deeper in classified would have found my factory 5 pinion set for sale with a beast shell for 300 bucks. All from a trailblazer ss. Also had a post for corvette servos and the small accumulator Pistons in aluminum. Oh well your going pretty good for a first time on it. I build for a living and looked through the post and looks good so far. If not pinched for time I would consider shipping you the planets and letting you pay me in 3 payments to help you out. If have any questions in the build hit me up any time. Lt1z350@bellsouth.net
