4l60e build with $100 core...
Old Oct 5, 2015 | 03:57 PM
  #51
Choda's Avatar
good for you doing this yourself! Props man
Old Oct 5, 2015 | 04:24 PM
  #52
Wolftrk99's Avatar
Thanks man, the hard part for me is the "go fast/upgrades" ive done few rebuilds before that were basically stock... Last shift kit i used was a b&m in a th350 which was a new seprator plate with a hole drilled in it, and would chirp the rear tires under light acceleration and break traction WOT in my 80 z28!! I decided to do this one myself for two reasons; 1- transmission is the only piece of this truck i havent had my hands in, 2- if it f's up i cant blane anyone but myself!!! After spending probably $4000 on other transmissions that were supposed to be built, i'm not much inclined to "order" a trans again, no offense to those who have or build transmissions, but not dealing with it again!! Its been stated i currntly run a mad dog that was supposed to be a level 2 with their more radical shift firmness and its so damn inconsistent, i cant believe they ever even let it leave with their name on it, take pride in your name and workmanship for ****'s sake!!! (Sorry, if i offend anyone with that but see it to much being in the business)
Old Oct 5, 2015 | 09:48 PM
  #53
GMCSIERRA5.3's Avatar
If i seen the pics right your have chinese 5 pinion planet set..i would recommend you remove them and go oem there not too expensive from amazon
Old Oct 5, 2015 | 10:09 PM
  #54
Wolftrk99's Avatar
I got those from transtar told me they werent, been wondering.... Got part number or a link??? Or should i just use 4 pinions i have
Old Oct 6, 2015 | 10:59 AM
  #55
heres how the oem 5 pinion planet set should look like..id use the 4 pinion before a aftermarket 5 pinion... http://www.ebay.com/itm/700R4-5-PIN-PINION-REAR-PLANET-PLANETARY-SET-GM-CHEVY-CHEVROLET-QUALITY-/281169038370?hash=item4176fb0c22&vxp=mtr
Old Oct 6, 2015 | 11:08 AM
  #56
Wolftrk99's Avatar
I dont have the extra $$ right now so i guess im goin back to the 4pinions, the gm 5 pinions need different ring gear too dont they??
Old Oct 6, 2015 | 10:53 PM
  #57
1FastBrick's Avatar
Custm2500's Rude Friend
No.
But as mentioned the aftermarket 5 pinions are junk.
Old Oct 6, 2015 | 10:58 PM
  #58
Wolftrk99's Avatar
Ive pretty mich decided to back to the 4 pinions, just dont have the extra $200-400 for the 5pinions right now....
Old Oct 7, 2015 | 12:45 PM
  #59
Wolftrk99's Avatar
More goodies came in....
7cs kit and the hd 2-3 valve should be on my door step this evening....
Old Oct 7, 2015 | 02:30 PM
  #60
Wolftrk99's Avatar
Fedex showed up.... Yay!!!
Shift valve and 7cs kit
Anything else yall think i should get...
