4l60 problem!!
Old Mar 22, 2015 | 03:48 PM
GM-only's Avatar
Default 4l60 problem!!
Well guys so I took my truck to the dragstrip for the first time after having 410s and a truetrac installed. I got there and hopped on after driving about an hour to get there and popped off a 14.5@94mph. After that I decided I would let the truck cool down some so I watched a few races for 25 or 30 minutes before going again. Well I got staged went to launch and nothing. Truck would not move forward. So I backed it up thinking that I had destroyed my second 4l60. Only to realize that everything still works so long as I shift manually. What could this be?
Old Mar 22, 2015 | 03:52 PM
GM-only's Avatar
If I start in second and then put it in drive it will shift fine. If I put it manually in 1st if engages. And will shift to second when I shift as well.
Old Mar 22, 2015 | 03:58 PM
GMCSIERRA5.3's Avatar
Broke the forward sprag
Old Mar 22, 2015 | 04:16 PM
GM-only's Avatar
That sounds expensive
Old Mar 22, 2015 | 04:24 PM
Borgwarner double caged sprag is only 40-45 bucks..but have to disassemble half the transmission lol goes inside the input drum
Old Mar 22, 2015 | 08:13 PM
GM-only's Avatar
Yeah that's a bitch. Well. I have my old transmission sitting here. Been saying that I was going to rebuild it. I guess now is the right time to have it done.
Old Mar 23, 2015 | 02:44 PM
GM-only's Avatar
I've also Heard something about lower rollers and apparently they break after a rear axle failure. I just had a rear axle failure
Old Mar 24, 2015 | 04:20 AM
Vince B's Avatar
It's a very common problem to have damage to both the low roller and the input sprag when having a catastrophic differential failure. The shock generally dimples the races in these components and shortly after a transmission failure occurs.
Old Mar 24, 2015 | 11:18 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You just can't buy that kind of knowledge.
Blwn99x
Mar 24, 2023 11:14 AM
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
