37's with 3.73 gears
Old May 16, 2006 | 04:38 PM
Default 37's with 3.73 gears
I have a question.....I have a new DD, its a 04 extcab 4wd with 6" lift, 35's and 3.73's. I want to run 37's w/a 3" bodylift but, don't want to change the gears and locker out yet. Would it hurt the Tranny to run 37's w/ 3.73's? or anything else? Thanks fellas.
Old May 16, 2006 | 04:45 PM
Quik's Avatar
5 year bitches!
dude youre already down on gear. with that added size in tires you wil lbe around 324s, no where near enough gear for those. 430s or 456 would be much more better for you
Old May 16, 2006 | 04:52 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yup. What he said. You are already hurting for gear. I am over tired with 32" & 3.73's.
Old May 16, 2006 | 05:04 PM
Could I swap out the gears with 4.56's and not have to change out the Locker?
Old May 16, 2006 | 05:13 PM
Quik's Avatar
5 year bitches!
yes but also remember with that much added weight of the tires, you put more stress on the axles themselves. i would look at upgrading to a stronger axle which means stonger carrier
Old May 16, 2006 | 06:31 PM
Post
I think you need more gearing than even the 4.56 gearing with that big of a tire. 4.56's work great with 35" tires. You need a lower ratio gear than 4.56.
Jim
Old May 16, 2006 | 06:37 PM
TIM Z's Avatar
11 sec. Truck Mod
i would at least go 4.56 also,and yes do a good limited slip while your back there.
Old May 16, 2006 | 08:10 PM
Thanks for the Input guys! I guess I will just run 20's and 35's, until I can get the Rear end stuff done.
Dan Neumann
11
Aug 7, 2022 09:06 AM
dragpac
Dec 8, 2015 05:48 AM
5.3Caprice
Nov 7, 2015 08:56 PM
ss454327
Oct 17, 2015 03:43 PM
Greatdivider
Sep 9, 2015 09:52 AM
