3.73, 3.90 or 4.10?
Old Mar 10, 2010 | 05:29 PM
crowleyk02's Avatar
Default 3.73, 3.90 or 4.10?
Who's running what and how do you like it?
Im going from 3.42 to one of the above mentioned gears with a Truetrac.
I have mostly full bolt on's minus Lt's but thats coming soon, with a Yank 2600 stall and will eventually be installing the Vinci "trucker" cam in the future. Just wanted to see what ya'll were running and what suggestions you have.
Thanks, Kyle
My truck is a rcsb 4.8 2wd, and this is my daily driver
Old Mar 10, 2010 | 05:33 PM
SSlow 4.8's Avatar
any of those will be okay... I've had all three. Not a huge difference between 4.10 and 3.90s but 3.73 is a nicer highway gear. Depends on what you're looking for. If you're looking to get out of the hole, 4.10s are great. What size tire are you running at the track and for daily driving?
Old Mar 10, 2010 | 05:40 PM
00ChevyScott's Avatar
Wearin' da big hat
What kind of 20s are you running? If they're a heavier wheel I'd suggest 4.10s or shorter. A 4.30 gear would be great for city driving.
Old Mar 11, 2010 | 11:34 PM
budhayes3's Avatar
PT's Slowest Truck
I have factory 3.73's with a 31" tall tire (on heavy 20's in the summer), and wish that my truck came with 4.10's from the factory...it's a small difference but enough that I'd notice
The 3.73's are great when I take road trips from NJ to Mass to visit my buddy though
Old Mar 13, 2010 | 12:01 AM
jiar577's Avatar
Don't even consider 3.73 unless they're free, not enough difference from 3.42 to be worth the time and $$$. As you already have full boltons you're headed towards performance. You know you want 4.10, besides the 4.8 needs all the help it can get down low, 20" wheels are heavy and need a lower gear to get them moving.
Your mileage should actually improve with 4.10
Old Mar 13, 2010 | 07:31 AM
mwbrannen's Avatar
4.56 i have them in my 4.8 rcsb and love em
Old Mar 15, 2010 | 11:52 AM
crowleyk02's Avatar
You really think the 4.10's would improve gas mileage. I was leaning towards the 3.90's but I also want to find a gear thats gonna be quiet but the only brand I found that carries the 3.90's is Yukon gear. Is yukon a good brand?
Iv'e heard the best gears are OEM but these trucks don't come with the 3.90 stock.
Mainly like I said above I want a good quality gear that will last a long time, run quietly, and I don't want the RPM's screaming down the highway.
Old Mar 15, 2010 | 12:38 PM
white1's Avatar
I have a CCSB with 3.23's and a 4.8. Ill be going to 4.10's in it.
Im also buying a RCSB with a 4.8, and Im assuming 3.42's. IMO going from 3.42's to 3.73's isnt worth the effort even if it is free. The 3.73's are a great ratio, IMO the 4.8 needs every bit of help it can get, so Id say go at least 3.90's depending on the tire size.
My CC runs 275/55 20 so thats about a 32" tall tire
Not sure what Im gonna run on the RC, but Im thinking Ill go 3.90 in it
Old Mar 15, 2010 | 12:56 PM
BLUES MAN's Avatar
The House is Rockin'
yup, there bitchin
Old Mar 15, 2010 | 02:23 PM
jiar577's Avatar
Well, in my case mileage improved with 4.10 because like 70% of my driving is in the city, and with 3.42 gears it took a lot of gas pedal to get moving from red light to red light. Now I barely touch the gas and the truck jumps forward a lot easier. I have stock tires 31.6".
On the highway I lost around 2mpg and I usually commute to work at around 65mph, but on average (city + highway) I gained 1-2mpg if I take it easy, which is hard to do with the 4.10 . To be honest lets just say on average my mileage stayed the same with the gear swap, with the added benefit that now I drive it like if it was a rental truck
What tire size do you have in there? This is important to choose the right ratio.
I have Yukon gears, quiet as stock.
