3/4 Suspension Drop
Old May 7, 2008 | 06:00 PM
Silverado_13's Avatar
Self proclaimed VILLAGE IDIOT
Default 3/4 Suspension Drop
Before telling me to use the search bar, I already did, and I still can't find an answer.
I NEED to drop my truck... It's too high. I finally have the funds to do so and would like to get it done within the next two weeks.
What do I need? Where can I get it? How hard is it to install?
Truck is 2001 Silverado Z71 ECSB. Still have the stock 16" wheels. I'd rather remove the stock lift blocks and use a 2" shackle in the rear, but I can't find the stock u-bolts anywhere...
Thanks
Old May 7, 2008 | 07:05 PM
I think I just found a kit. Anyone know where I can find stock u-bolts or what the measurements of the bolts are?
Old May 7, 2008 | 10:25 PM
SnakeOiler's Avatar
did you try the dealer? they can also tell you how long they are.
from what I remember the 2wd are 180mm and 4wd are 230mm
Old May 7, 2008 | 10:45 PM
Yea. I tried the dealer. They were no help to me at all. Guy even told me that the u-bolts were the same in ALL the vehicles that GM made... I turned around and walked out when he said that...
Old May 8, 2008 | 10:36 AM
1989k1500's Avatar
Just tell him you have a 01 ecsb 2wd 1500 and need the rear u bolts. He cant really **** it up when hes just looking in the computer.
Mines shackle/hanger, block out and spring clamps, then keys in the front.
Old May 8, 2008 | 01:12 PM
budhayes3's Avatar
PT's Slowest Truck
Same here minus the hangers I'd like to do some hangers and spindles someday.
Old May 8, 2008 | 01:17 PM
SSlammed03's Avatar
go to the junkyard and try to get some off another truck... on mine i have lower control arms in the front and in the rear i have a flip kit with shakles so its a 4 8 drop
Old May 8, 2008 | 05:13 PM
absmith's Avatar
Is your truck 4wd?
Old May 8, 2008 | 05:21 PM
VroomVroom's Avatar
If it helps, here's the p/n I used for the 2wd u-bolts:
15002781
You'll need four (duh). As I recall, I spent just under $40. Once you're down 4" (I only went down a total of 3" - I used 1" shackles) you'll want to at least pull the bump stop brackets, and you may want to either trim or replace the stops themselves. I also replaced the shocks, going with Bilsteins...I can't remember the p/n but they were the standard shocks for 2wd 1500 trucks. I hope this helps - good luck!
walledition
Feb 24, 2026 03:27 PM
Superman09
Sep 25, 2015 05:55 AM
Boyes50
Sep 8, 2015 12:06 PM
Sdailey
Sep 6, 2015 10:26 PM
