2/4 drop questions actually raising it?
Old Jan 29, 2013 | 10:24 PM
Dustin Sykes's Avatar
Default 2/4 drop questions actually raising it?
so ordered a 2/4 drop
spindles and flip kit but flip kit lowers more than 4"
so it has shackles and hangers as well which supossedy raises it
so question is their only one hanger on each side to remove? torwards front or back im confused after looking at pics on djm website
Old Jan 30, 2013 | 12:14 AM
GMCSIERRA5.3's Avatar
Theres one on each side along with the shackle flipkit is 6 inches from jdm i believe so 1 inch lift shackle plus lift hanger = 4 inch drop
Old Jan 30, 2013 | 01:13 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
What year is the truck you're working on? 2 or 4 wheel drive?
Old Jan 30, 2013 | 01:50 AM
VegasJ's Avatar
DJM's instructions were a bit difficult for me too.
The shackle and mounts are in the back.
They also look like they are exact mirror of each other, but I could get one on one side and vice versa, but wasn't able to switch them.
I also had to grind a little in the bends of the shackle they provide because the rear rolled edge of my leaf spring was hitting and not allowing the bolt hole to align.
My flip was a 4-5". Flipping drops it I think 7", then the lift hangers brings it back up to 4" if you use the bottom hole, 5" using the inner one.
edit:
maybe this'll help. The red arrows are just pointing to where the roll in the leafs hit, the green line is how much I had to grind. But here's a pic of the DJM shackle & hanger in
Old Jan 30, 2013 | 05:20 PM
nice thank you and truck is an 08 crew cab
Old Jan 30, 2013 | 07:39 PM
Only thing sucks is that the hangers on crewcabs are welded..so get the torch ready man GL
Old Jan 30, 2013 | 07:49 PM
thought the front were welded and rear were riveted
Old Jan 30, 2013 | 11:20 PM
On an 08, the rear is riveted. And the shackle flip will lift the rear back up, which takes away from the 7" drop of a normal flip kit.
Hope that helps.
Old Jan 31, 2013 | 06:04 PM
hell yeah glad to know the rears the ones i need to remove are riveted! Thanks AK
Old Jan 31, 2013 | 06:16 PM
VegasJ's Avatar
mine on the rear were riveted.
chisel and hammer a little grinder and they were off.
maxspeed05V
Nov 11, 2015 04:20 PM
Lamartian92
Sep 10, 2015 09:27 PM
USMCvet0311
Aug 1, 2015 07:45 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
KleanKustoms
Jul 18, 2015 10:08 PM
