15x10 custom backspace
Old Jan 1, 2009 | 08:28 PM
tarinitup's Avatar
9 Second Truck Club
Default 15x10 custom backspace
I found a place that makes 15x10 and 16x10 wheels for our trucks with backspace up to 7''. Cost for two powdercoated 15x10 steel wheels would be about $300 shipped.
What is the max backspace before hitting the banjo bolt on trucks with disk brakes? TXsqueeze ran 6.5 but that was on drums and he seems to think a 6 BS would fit. Can anyone comfirm this before I order next week. I plan to use 29.5x11 hoosier full slick and don't want them to stick out too much.
Old Jan 2, 2009 | 01:06 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
I would get them in 16X10 with 6.5 backspacing Max 7. Care to share were you found the wheels pm please? Thanks
Old Jan 2, 2009 | 01:07 AM
Low_LSX's Avatar
I'm running 18X10 with 6.5 backspacing
Old Jan 2, 2009 | 01:18 AM
RandomHero's Avatar
In order for them to tuck there needs to be a 3" difference between wheel width and backspacing. I would say something around a 3-4" difference in width/backspacing wouldn't look too out of place.
Old Jan 2, 2009 | 01:26 AM
AustinDesigns's Avatar
Originally Posted by Low_LQ4
I would get them in 15X10 with 6.5 backspacing Max 7. Care to share were you found the wheels pm please? Thanks
15x10 with 6.5" backspacing WILL NOT clear the banjo bolt. We tried fitting mine on a guys 03 at the track, ground the calipers a little, wheel went on, but as soon as you started tightening up the lugs the wheel would not turn. Looked behind the wheel to see if it was still hitting on the caliper, and found that it was hitting the banjo bolt.
Manny, if I get around to it tomorrow, I'll take off my wheels on the blue truck, and measure to see how much backspacing you will be able to get away with.
Old Jan 2, 2009 | 01:32 AM
Low_LSX's Avatar
Sorry I meant the 16X10
Old Jan 2, 2009 | 01:37 AM
Went outside. The lip is exactly 7/8" from the banjo bolt on stock 16" aluminum wheels. Don't know their backspacing, but that will give you a place to start.
Old Jan 2, 2009 | 01:47 AM
https://www.performancetrucks.net/fo...ck+backspacing
Read that thread. Read post #18........
To clear it up, my 7/8" measurement is to the block, not the banjo bolt holding it. Would be a hair over an inch if I had measured to the bolt.
Old Jan 2, 2009 | 03:51 AM
jasond26's Avatar
I have 16x10 w/6.5 backspace and it clears. I had to grind the banjo bolt a little bit but nothing major. My street wheels are 22x10 w/7.5 and they clear no problem.
Old Jan 2, 2009 | 07:25 AM
tarinitup's Avatar
9 Second Truck Club
Thanks for the posts. I know 16" with 6.5BS will clear but I want 15" for taller slicks. I will try out 6" BS and post results. It takes about a month to get them so it will be a while. Will post or pm place later this evening.
