15inch rim on back of a 01 silverado?
Old Mar 18, 2011 | 08:39 PM
oldscooltroy's Avatar
Default 15inch rim on back of a 01 silverado?
Will a 15inch rim clear the brake caliber on the back of a 2001 silverado?
Old Mar 18, 2011 | 08:52 PM
quicksilverado's Avatar
They will fit if you grind the calipers.
Old Mar 18, 2011 | 08:59 PM
Bout how much do i need to grind? Just tryin to figure out if its worth getting 15inch rims not.
Old Mar 18, 2011 | 09:34 PM
skeet's Avatar
alot, grind test fit, grind test fit, grind test fit
Old Mar 19, 2011 | 08:25 AM
blown02408's Avatar
02 w/ lowest mileage 2800
depends on the rim and backspace. My rear is narrowed and I only run a 4 1/2" backspace but I had to grind a little more than an 1/8" off. Remember any more than a 5" backspace and you'll have to swap to S10 Calipers.
Old Mar 19, 2011 | 09:29 AM
TXsilverado's Avatar
you have to swap your silverado calipers for s10 calipers, then grind the ever living dog **** out of them
Old Mar 19, 2011 | 01:08 PM
06Sierra2's Avatar
sounds like its easier to run a 16 or 17in rim
Old Mar 19, 2011 | 06:49 PM
yeah it sounds like its easier to stick with a 16 inch rim, i think imma just get some et streets that are 28/11.5-16 and try to hook on those. last time i went to the track i was roasting my 26 inch et's so in hoping a 28 will give enough sidewall so i can bite.
Thanks for all the help!
Old Mar 19, 2011 | 07:21 PM
rhinosarge's Avatar
just stick a 1in adapter so you can clear ..
im just saying.. NO GRINDING
Old Mar 21, 2011 | 02:15 PM
04gibbstahoe's Avatar
So do the s10 calipers have a lower profile than the stock silverado/SUV rear calipers or is the Banjo bolt just in a different spot?
