14bolt SF into 98 Suburban
Old Apr 29, 2009 | 06:29 AM
howard quick's Avatar
Default 14bolt SF into 98 Suburban
Thought I'd post this here.
I looked everywhere and couldn't find a breakdown of the drum brakes on a 14 bolt 9.5" SF rear.
Took about a year to get my diff shipped over from Canada. Got a mate to ship it with a new Trutrac to suit as the G80 was damaged.
Had the housing, backing plates and mounting hardware sandblasted and epoxy coated. Had the drums blasted and painted with 'caliper and drum' high temp paint.
Made and welded in a stainless sight glass unit with drain and fill plug.
Finally got my 14bolt SF sandblasted and epoxy coated.
Had the drums blasted and then painted them with drum and caliper high temp paint.
Having a stainless plate made at present which will be welded into the cover. It'll contain fill, drain plugs along with a sight glass.
Problem is...I pulled the whole brake assembly apart to wire wheel and paint everything (it was pretty rusty) and can't remember how it all goes back together.
Anyone got any pic's?
Old Apr 29, 2009 | 06:31 AM
Here's a quick 'how to' on putting together the drum brakes of a 14bolt semi floating rear axle assembly.
LEFT WHEEL!
Old Apr 29, 2009 | 06:32 AM
Old Apr 29, 2009 | 06:33 AM
Old Apr 29, 2009 | 06:34 AM
Used a piece of folded cardboard to hold the hook up top make it easier to connect the spring.
Old Apr 29, 2009 | 06:36 AM
Got the plate welded in and tested for leaks (using CRC....any pin hole in a weld...CRC will find it).
Now need to get the cover re-epoxied.
Old Apr 29, 2009 | 10:02 AM
oldred95's Avatar
Very nice work. Your attention to detail is amazing. My ADD kicks in before I could ever get that meticulous on anything like that.
Old Apr 30, 2009 | 07:22 PM
Lol! Thanks.
calsdad
Jun 14, 2023 11:07 PM
cheyenne383
Nov 13, 2015 09:24 AM
ice17
Sep 22, 2015 05:18 PM
11MPG
Sep 8, 2015 04:52 AM
