10 Bolt frustration?
Old Aug 30, 2010 | 06:48 AM
dhpro's Avatar
Default 10 Bolt frustration?
Well...the whine from the rear end is getting pretty bad. It sounds easily as bad as in the spring when we found the pinion was cracked the entire length of the gears Its driving fine except for the sound, but Im obviously not ripping into it. I'll have to tear it apart and see whats up, but as this is already my 3rd set of gears, is the 10 bolt just not buildable to handle the beating? Im really not all that keen to spend $1500-2k for a whole rear end, but Im getting damn close at this point already! Opinions? Recommendations?
Current: Richmond ring&pinion - 3.73
Auburn Gear Locker
Old Aug 30, 2010 | 07:27 AM
mhotrodscooter's Avatar
Who's putting the gears in? 3rd set something not right! Might be time to get the rearend checked for cracks or go 14 bolt!
Old Aug 30, 2010 | 08:12 AM
BLUES MAN's Avatar
The House is Rockin'
as stated above, your installer is fubaring up your gears. GEARS SHOULD NOT WHINE (if set-up correctly). altho i have heard of rare occasions when richmonds whine, even when everything is spot on.
ohh and by the way, mine whine
Old Aug 30, 2010 | 08:39 AM
dhpro's Avatar
I was hoping it wud just be a fluid change and additive to cure it, but I've been down this road before and dont wanna chance it. First replacement lasted 2yrs, second 3months - the second wasnt done by a specialist so I really was crossing my fingers! After a bit of research it seems a whine can be caused by improper breakin resulting is abnormal wear, which will eventually tear off teeth!!! I'm also told that the 07+ 14 bolt w/ 4.10's is a direct replacement...but that means ~$1500 + front gears to match + misc = $2500-3k...what a clusterfuck! Prob do replacement gears again for now
Old Aug 30, 2010 | 08:40 AM
BLUES MAN's Avatar
but who is doing your installs?
Old Aug 30, 2010 | 09:03 AM
ap2002's Avatar
Have you always used richmond gears? Try swapping to a different brand, ive also heard that richmond gears whone some..
Old Aug 30, 2010 | 09:09 AM
LightFighter's Avatar
My Ava came with 4:10's from the Factory!!! yeah i would def check out who is installing the gears........
mikeyjm1
17
Oct 29, 2015 11:04 PM
Justin87gn
Sep 10, 2015 12:06 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
hackrst
Sep 2, 2015 05:27 PM
