1 blown G80!!
Old May 14, 2005 | 06:35 AM
  #31
JERRY2500's Avatar
14 Second Truck Club
Damn Grippy , I don't know if i can beat that time. Sorry to hear about the G80. I'm waiting for mine to blow. I think it may have something to do with scheduling track day on Friday the 13th. Kind of sounds like my last track day.
Old May 14, 2005 | 07:06 AM
  #32
Kano's Avatar
pull the pan
lets see what it tore up
Old May 14, 2005 | 07:29 AM
  #33
KySilverado's Avatar
Tough break. No pun intended. Part breakage has gotta be expected. Just moving the weakest link on down the line.
Old May 14, 2005 | 07:36 AM
  #34
L82gofast's Avatar
I put a Auburn posi in after I got tired of using the right rear as an eraser through intersections It has worked great since then. Don't bother with another G80....
Old May 14, 2005 | 08:30 AM
  #35
moregrip's Avatar
what a rush!
Originally Posted by 8100hammer
hmm must be a problem with the 10.5 rear ends, Duramax guys' run a eaton e-locker up front and stock G80 out back on the 11.5 rear ends truck pulling, seem and never heard of any problems on the 11.5.
So They make aftermarket locker for the AAM 10.5 now ???
For reference:
There two GM 10.5 full floaters,
Old Corp 10.5" 14 bolt, which use three bearing support on pinion gear. Third bearing support is on the end, cradleing the pinoin gear.
New AAM 10.5 14 bolt, which is made by American Axle and Manufacturing, uses the regular and more common style pinion bearing support where the pinion over hangs the bearing.
It's the newer AAM, the 10.50" G80 seemed to be a stout unit according to what I've read, however, real world, well, not so impressive.
Now that I think about, traction has been an issue for me since day one of the Radix install, and lately it didn't seem to bark off the line like it used to.......maybe too many G-tech 0-60 runs.
I wouldn't say I'm exactly hard on it, but I'm not easy on it either
Old May 14, 2005 | 08:32 AM
  #36
moregrip's Avatar
what a rush!
Originally Posted by bud8fan
**** HAPPENS!!!!i'm watching mine also...it spins 1 tire sometimes and makes noises but is still running for now..anyway better luck next time there grippy
Amen brother
Old May 14, 2005 | 08:34 AM
  #37
moregrip's Avatar
what a rush!
think you can keep my tail lights in view?
next track day is June 17th, I will dyno before then
Old May 14, 2005 | 08:39 AM
  #38
JERRY2500's Avatar
You must mean headlight in my rear view mirror. I hope you have better luck next time. I finaly got the meth hooked up. I'm going do some test runs today. Hope my g80 holds up
Old May 14, 2005 | 08:41 AM
  #39
moregrip's Avatar
what a rush!
Awesome! let me know how it goes!
Old May 14, 2005 | 08:42 AM
  #40
moregrip's Avatar
what a rush!
Originally Posted by gamedawgx53
pull the pan
will do, sometime today
