will a spin on diesel style fuel filter work on a gasoline fuel system
Old Feb 26, 2014 | 07:23 AM
oldred95's Avatar
Default will a spin on diesel style fuel filter work on a gasoline fuel system
It seems like all I see are small inline strainer type filters for gasoline fuel systems. I know the gasoline injectors are way more forgiving about debris in the fuel then a diesel injector but would higher filtration hurt anything so long as it flows adequately?
I'm thinking this filter housing:
Vulcan Performance | VUL-SRFF | Vulcan VPMAX Universal Single Remote Filter System - Alligator Performance
With a Cat filter would work. The Cat filters are 2 microns and cost 10-15 bucks and I have a stack of them around because thats what I run on my duramax. Thoughts?
Old Feb 26, 2014 | 07:24 AM
Atomic's Avatar
I have a gauge for that
As long as they would flow enough it would be fine. Might want to measure the pressure before and after it with gas pumping through it. If its only 1-2 psi it would be fine, but if its 5 or 10 you might have a problem.
Old Feb 26, 2014 | 05:24 PM
oldred95's Avatar
Sounds like a plan Stan.
Old Feb 26, 2014 | 09:18 PM
68haywagon's Avatar
Don't diesels run at low pressure to feed the injection pump? I thought the d-max only runs at 10psi to feed the pump.
Old Feb 26, 2014 | 09:26 PM
BlackGMC's Avatar
Resident Retard
Here is my filter. Is it big enough for you?
Old Mar 1, 2014 | 08:18 AM
oldred95's Avatar
In stock form the duramax engines rely on the injection pump to suck diesel out of the tank, through the filter and up into the pump. Lift pumps can be added but once you get over 8 psi at idle the idle quality can become erratic. The Cat fuel filter I would use is constructed like any spin on engine oil filter so I don't see any reason why it couldn't handle the pressure.
Old Mar 1, 2014 | 11:04 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Pretty sure those filters & bases aren't designed for 65+ psi.
Old Mar 1, 2014 | 01:14 PM
dirt track racer 81's Avatar
Yea.. Not a good idea..
5.3Okasai
Mar 9, 2022 01:07 PM
lxcoupe
Jul 21, 2015 02:12 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
4B11T
Jul 13, 2015 03:48 PM
Deceptarado
Jul 8, 2015 05:24 PM
