will 60lb injectors be too big with my setup?
Old Jun 7, 2014 | 01:48 PM
2doorfury's Avatar
Default will 60lb injectors be too big with my setup?
I'm running a LQ4 with stage 3 243's,moderate size cam, edelbrock pro flo intake, and a 150 shot. Will 60lb injectors be too much? My tuner is worried about tuneability with these big injectors. Will he have a problem or could he tune accordingly?
Old Jun 7, 2014 | 01:51 PM
2doorfury's Avatar
Also. I have a adjustable fuel pressure regulator. Could I turn down the fuel pressure to the 43.5psi the injectors were rated for to put them at the rested output, rather then the 58psi that would put these at 60psi?
Old Jun 7, 2014 | 01:52 PM
smokeshow's Avatar
Mod with training wheels
Depends on what 60s they are...
Old Jun 7, 2014 | 01:55 PM
2doorfury's Avatar
They are ev6 rated at 52lbs at 43.5psi
Old Jun 7, 2014 | 02:17 PM
Chevy_King1500's Avatar
they will be fine, its not any different than having large injectors for a small cube (4.8) and big charger.
i think smokeshow is referring to having good injector data.
Old Jun 7, 2014 | 02:21 PM
2doorfury's Avatar
I won't be running a charger. Just will be N/A with nitrous. As long as they will be tunable. I think that's what he's worried about.
Old Jun 7, 2014 | 03:15 PM
they are not big by any means, I'm guessing you'll be in the 550+ hp range. and the injectors will be 80% duty cycle or more .
do you have the pulse width data on them?
Old Jun 7, 2014 | 04:23 PM
2doorfury's Avatar
I do but I gave it to my tuner when I dropped the truck off. He was just worried about tuneability with a larger injector. He was telling me his 402 stroker in his vette has 42lbers that barely break 80% duty cycle. That why he was wondering if we would possibly have any issues
Old Jun 7, 2014 | 05:07 PM
03sierraslt's Avatar
Assuming you are running a wet shot those injectors will not have to work very hard in your setup. They should be fine though, tuned properly they will behave just fine.
Old Jun 7, 2014 | 06:16 PM
2doorfury's Avatar
Good deal. I was hoping they'd work out alright. Yes, its a wet shot
