Walbro 450 In 99-03 Bucket
Old Mar 25, 2022 | 05:39 PM
  #31
1redta's Avatar
what about using the Holley hydra mat fuel pick up instead of the sock?
Old Dec 10, 2023 | 01:42 PM
  #32
riddler28's Avatar
Registered User
Originally Posted by xx_ED_xx
Pics of how i did mine and doesnt starve go figure when you do it right
Just to clarify.. you had the 450 with sock inside and you had starvation under 1/4 tank.. Now you moved filter outside like stock and now have no starvation? Thanks
Old Dec 10, 2023 | 02:39 PM
  #33
xx_ED_xx's Avatar
I actually swapped a different fuel pump prior and then saw all the threads about keeping it above 1/4 tank which is the same issue i had. So when i did the 450 swap i did it this way and had no issues. It finally died after the third truck i swapped it in and 8 years later. I also updated the wiring stock plug and wiring isnt rated for the amps these pull.
Old Jul 11, 2024 | 05:21 PM
  #34
Fullpower's Avatar
I'd like to BUMP this thread, with the same question:
Holley HydraMat, fit to a AEM340 LPH in stock GMT800 bucket.
Is that sufficient to run the last few gallons out of 31 gallon Suburban tank, or is that "Living Dangerous" ?
Also:
for those that have run 12 gauge POWER direct to in tank pump, no problem with using the silly fuel tank PRESSURE sensor port for power wires ?
What is good for sealing the top of fuel tank HAT ?
Will JB weld hold okay on top of gasoline/ ethanol + whatever they blend into fuel these days ? ?
Last Call
Mar 19, 2014 01:01 PM
TurboNgo
Feb 17, 2014 04:55 PM
AkSSS
Jan 31, 2014 10:24 AM
02_Orange_D1SC
Jul 12, 2013 05:27 PM
Ferocity02
Mar 29, 2012 11:02 PM
