how to set up dual walbros without sucking bucket dry
Old Feb 15, 2014 | 05:40 PM
TurboNgo's Avatar
Default how to set up dual walbros without sucking bucket dry
got a 00 z71 turbo looking for 800+hp on e85. my question is what is the correct way to run off of dual walbro 450s and not have to stay above a half a tank?
Old Feb 15, 2014 | 06:02 PM
oakley6575's Avatar
I'm building a bucket set up right now for two Walbro 450's. I drilled and dremeled out a press fit hole for the walbro sock to press into on the bottom side of the bucket. That way, the main pump is always sucking fuel from the bottom of the tank. The second pump will run off a hobbs switch and will suck fuel from inside the bucket. Should work okay but haven't tried it out yet.
Old Feb 16, 2014 | 05:07 PM
TurboNgo's Avatar
Let me know how that works for you! Sounds like it should work good!
Old Feb 16, 2014 | 06:14 PM
smokeshow's Avatar
Mod with training wheels
Once you start making enough power where draining the bucket becomes a problem under 1/2 a tank, your truck should have enough g-force where fuel likely won't be near the bucket anyway. I would just keep the fuel level high unless you have a sumped tank.
Old Feb 16, 2014 | 06:27 PM
lycominghunter's Avatar
Anyone have a PN or link for one of them there walbro fuel sock/strainer?
Old Feb 16, 2014 | 07:59 PM
oakley6575's Avatar
Which walbro?
Old Feb 16, 2014 | 08:15 PM
TurboNgo's Avatar
Might be a dumb question but when you run a sump tank you run inline pumps instead of intank pumps
Old Feb 17, 2014 | 04:55 PM
Oak, the walbro 450...
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Raggedz71
Jul 29, 2016 10:20 AM
Silveradorst07
Dec 31, 2015 12:04 AM
Sexyrado327
Aug 2, 2015 04:08 PM
USMCvet0311
Jul 29, 2015 01:28 PM
