Question about rail plumbing for return conversion
Old Nov 10, 2015 | 10:26 PM
lxcoupe's Avatar
Default Question about rail plumbing for return conversion
I'm curious about everyones opinions on plumbing the return rails. My particular application is a 2005 Silverado which I am turbo'ing and will be running E85 and ID1000's. I've read that I can Y and run two individual hoses to the back of the rails then run each rail to the regulator (preferred way). But that is a plumbing headache
What will be much easier is if I run the -8 feed to the rear of the driver's side rail, then run the passenger side rail to the regulator and cap the 2nd port on the regulator (and obviously run a crossover at the front of the rail).
Anyone have an opinion either way?
"Preferred way"
My way (top):
Old Nov 10, 2015 | 11:05 PM
BlackGMC's Avatar
Resident Retard
I tired the "preferred" way, i did not like it... it cost a small fortune in fittings... Way to complicated... It did work fine thou... I ended up swapping to the setup you have pictured second... It was kinda fun to make but simpler is always better. I have also tried the dead head way too, no issues with that either...
Old Nov 10, 2015 | 11:28 PM
lxcoupe's Avatar
Corey big thanks! Always nice to hear what's proven. I have literally stalled my project by weeks by cutting, refitting, maneuvering y fittings so I can somehow plumb them into each side, etc etc. I have several hundred dollars in fittings that I still need to return. I will run it the simple way pictured second. F**k the truck would be running had I not over thought this.
Old Nov 10, 2015 | 11:38 PM
GMCtrk's Avatar
Running a feed to each rail is one of those things that seems preferred in theory but really doesn't make anything difference versus doing a crossover at our power levels.
The most important thing is to have the regulator after the rails.
Old Nov 11, 2015 | 06:48 AM
03sierraslt's Avatar
I have mine ran like the 2nd picture.
Old Nov 11, 2015 | 11:44 AM
TrendSetter's Avatar
i have had great luck with the last layout, dead heading. I dont have a choice though because im running a oem returnless fuel rail.
Old Nov 11, 2015 | 12:23 PM
BlackGMC's Avatar
Resident Retard
Just my opinion on the dead heading option is to have regulator as close to the rails as possible. When i had that setup it was only ~6in away. Seemed to work fine for me. But option 2 is the easiest and is proven.
Old Nov 11, 2015 | 12:28 PM
BlackGMC's Avatar
Resident Retard
One other thing is testing the system. Buy the testers they are cheap. Cap off the feed and return at the bucket. Pressurize the whole system with 100psi with compressed air. Get a squirt bottle with soapie water and spray every fitting and injector. If you get bubbles then You have a leak.
Old Nov 11, 2015 | 01:29 PM
Atomic's Avatar
I have a gauge for that
^ dont be a wuss, smoke a cigar and just pressurize with gasoline
I have done both both ways, liked the second way better. Pumps to back of one rail, crossover, then end of other rail to regulator.
Old Nov 11, 2015 | 02:58 PM
Vortec350ss's Avatar
When I finally kick my *** into gear I will do option 2...
