NNBS Returnless Walbro 450, CTSV FSCM write up
Not sure I understand what you are asking? Your options are: write entire, write calibration or do not write. I only write calibration. If you don't mind me asking, what are the codes your brother is getting? What is the part number of the FSCM?
For the tuning portion of this, it is just a matter of opening your tune then the 09 CTSV as a compare file. The desired pressure tables, i have changed and are a mix of my stock file as well as the high flow pressure, i have set at 75 psi. You can work these tables to whatever you are wanting to achieve. Just remember, if you are wanting to achieve a certain pressure in the ECM, ensure the FSCM portion will allow it. Think of the ECM as the requester and the FSCM as the ultimate decision maker.
I am attaching two CTSV files. The one labeled 1358810452.hpt was taken from the HPtuners repository. The other labeled 09 CTSV FSCM that is from my truck after installation of the CTSV FSCM.
1358810452.hpt 2009 CTSV ECM Only
09 CTSV FSCM.hpt 2009 CTSV FSCM Only
You can see the tables that differ by the green tabs. Copy from the CTSV and paste the parameters to your tune.
First is the ECU which will be required by anyone doing this mod regardless if you purchased a new programed FSCM or not. Copy and paste the red circled tables.
Here is how i currently have my desired pressure tables set up.
Under System there is a fuel system voltage tab. Copy and paste this table.
Now, for the FSCM. This is only required if you didnt buy the new programmed FSCM. Again, copy and paste the red circled tables to your tune from the CTSV tune.
Now go and log it to verify operation and you now have a fuel system that will handle, i have no clue how much power
I do know its working great on my turbo 4.8 with CTSV injectors. Hopefully others with more power will find the limit at some point and can post here. If, one of the mods can sticky this.... that would be awesome. Let me know if there are any questions.
It's an 08 Sierra Denali 6.2
Pump is the AC Delco MU2142 (from a 2010 Sierra Denali 6.2 L9H)
FPCM that DID NOT work: 20898936 (from a 2010 Sierra Denali 6.2 L9H)
After that did not work, I realized that the FPCM's were broken out by trailer brake (Option JL1) and no trailer brake. His truck doesn't have a trailer brake, so we ordered FPCM 20791901/20877116 (2010 Sierra without JL1). I don't think it's because of the trailer brake, but that is the only difference.
With all that said, I had HPT and could have flashed it. lol I use EFILive, but bought HPT to learn some of the new stuff. Guess I should use it more.
Codes were: P069E and P2635 (immediately after the new fuel pump was installed).
I have HPT 3.4, that is why I cannot access the FPCM tables. I'm going to email HPT support in a few minutes. I didn't know if 3.5 had something to write just the FPCM, which it doesn't.
The FSCM part numbers and operating systems in these trucks are all over the place. For instance, Trailer brakes that you mentioned. This is why we are not flashing the CTSV OS and just changing the calibration. Either one of those FSCMs should work although I would try to use the original.
FYI, after you get the BETA, to see the FSCM data, you must to do a read entire from it before the tables will show up. It generates the file for you from the VIN stored inside the FSCM and will only give you a stock file. I keep the FSCM portion separate from the truck file.
Thanks for posting back, finally getting around to this.
FPCM 20791901 generated the same codes, so the trailer brake option does not affect anything.
I compared the 2008 Denali tune (L92) to a 2010 Denali (L9H) in HPT. The only difference in the ECM is the default pressure.
I'm going to download the FPCM info from my 2011 Tahoe Flex-fuel and compare that to the info he has with the stock 08 FPCM. I could not compare FPCM info on the two files you had posted. I think because the stock V tune was not read with Beta.
I plan to use the 2011 FPCM settings in the 2008 FPCM. Hopefully it cures the low flow code. Will respond back either way.
So I got the HPT Beta and installed it. Read the tune with it and I think there are a few items missing. Namely the "Fuel Pressure" values from FPCM. I assume that HPT has not defined them yet? I pasted a picture of what the read looks like below:
I'm going to update the FPCM with the "Fuel Pump" values. But considering I'm getting a low fuel flow code, I think the changes need to be made to the pressure portion of the FPCM. Which of course I don't have right now!!
Attachment 80497
Attachment 80497
I think the two most important things I am missing:
Max desired pressure
Regulation pressure
If all else fails, I will update the following to see if there is a difference:
Openloop DC
Openloop DC Multiplier
Min DC
