New less expensive fitting for Hi-Ram and 145amp alternator!
Old Aug 16, 2015 | 02:55 PM
Roach Coach's Avatar
Default New less expensive fitting for Hi-Ram and 145amp alternator!
I found this fitting in the new Earls catalog because like most of us I don't want to pay $55 for a stupid adapter fitting for my DS fuel rail and alternator clearance issue. The part number is: AT849008ERL and it was $35.xx from summit! The plus side of it is its a -8 hose end too. This may have been known already but if it's not its a lot more readily available than the XRP lo pro adapter.
Attached Thumbnails New less expensive fitting for Hi-Ram and 145amp alternator!-image.jpg
Old Aug 17, 2015 | 10:13 PM
TAPyvehc93's Avatar
Thanks! I'll be needing one of these. Dumb question though, how do you tell which alternator you have? If I have the bigger one, can I just replace it with the 145 without any issues? I want to install my Holley regulator onto the passenger side fuel rail.
Old Aug 18, 2015 | 07:29 AM
03sierraslt's Avatar
Can you get a measurement of how much it comes out of the rail? I may need one also.
Old Aug 18, 2015 | 08:45 AM
Atomic's Avatar
I have a gauge for that
That looks like the one I used. I had to trim the back plastic of the big alternator but it fit with a hairs clearance!
Old Aug 18, 2015 | 10:06 AM
BlackGMC's Avatar
Resident Retard
speedflow makes a pretty nice AN to Oring 90*
Old Aug 18, 2015 | 06:29 PM
TAPyvehc93's Avatar
That looks like its just as big as a regular 90*
Old Aug 18, 2015 | 06:44 PM
GMCtrk's Avatar
That fitting eliminates the ORB to hose end fitting on the end of the rail which causes the interference. It will save quite a bit of length and give good clearance.
Old Aug 18, 2015 | 06:46 PM
BlackGMC's Avatar
Resident Retard
Speedflow makes some good fittings. Only problem is that they ship from Austrailia.
Old Aug 18, 2015 | 08:22 PM
TAPyvehc93's Avatar
Hmm. Maybe i'll have to try it. I like how its a smooth bend. Not sure if that will work with the big alternator though.
Old Aug 30, 2015 | 10:37 AM
SloSVO's Avatar
We ended up using the 90 fitting from Fore.. aint cheap but clearance up the gazzo
