Need advice: fuel pump
Old Jul 18, 2020 | 10:30 AM
meatwad's Avatar
Fast lane preferred
Default Need advice: fuel pump
As far as I know my 03 pump is stock. Just installed a wideband and am seeing very lean conditions at WOT. Changed fuel filter with a little improvement. Today I heard a squeal at the tank with KOEO, so I suspect my elderly pump is on the way out. Haven’t checked fuel pressure yet.
I am probably only 350 whp right now, but plan to do a tvs 2300 much later down the road.
I had planned on doing the walbro 450 try not to hack the bucket approach when I go boosted, or maybe a 340 drop in unit from rpm speed. I’d prefer to change the pump once and be done, but worry the big *** pump would be too much for my current setup. Though I am running an aeromotive regulator on the frame rail, installed when the Ly6 went in to deal with stock return system. Shop that dropped the engine in chose that method.
Should I just go stock pump and hold on a bigger pump for later when it is truly needed?
Old Jul 18, 2020 | 05:16 PM
wretched73's Avatar
Just something to check out before making your decision-
My truck, '05, I replaced the whole fuel pump assembly. The "hat" that is on top of the fuel tank is metal and was rusted all to hell. You might want to verify yours isn't metal or if it is, is rust free.
Old Jul 18, 2020 | 05:23 PM
meatwad's Avatar
Fast lane preferred
Good idea, but I think 03 and older had the smaller buckets with the plastic hat. I assume my lock ring is more rust than metal though.
dmelvin
Dec 31, 2010 12:27 PM
ap2002
11
Jan 11, 2007 07:17 AM
Lurius
Jan 7, 2007 12:24 AM
chris99gmc
Jan 11, 2005 03:17 PM
hohl
Jul 19, 2003 02:40 PM
