LS3 Injectors into a NNBS Intake
Old Aug 14, 2013 | 01:25 PM
cdub81's Avatar
Default LS3 Injectors into a NNBS Intake
I got some LS3 injectors for a good price, I purchased these height adapters to go on the TOP side.FUEL INJECTOR CONNECTION - Height Adapter 1/2"
My question is on the orings... Where the injector goes into the intake the stock LS3 injector oring looks to small/skinny.
Does anybody know the correct size oring to make these work with this intake?
Old Aug 14, 2013 | 03:15 PM
Fastcount03's Avatar
I'm not sure on those adapters, the ones I used went on the bottom and the injector fit perfectly into the adapter, but I had to drill out the intake for the adapters.
Old Aug 14, 2013 | 03:17 PM
These may be opposite of what you need, but I tried... lol
GM LS2, LS3, LS7 Intake Manifold Adapter Fuel Injector O-rings - Lingenfelter Performance
Old Aug 14, 2013 | 03:18 PM
These are what I used.
http://www.summitracing.com/parts/fs...FcqZ4AodFigAyw
Old Aug 14, 2013 | 05:40 PM
cdub81's Avatar
Thanks man, from what I researched the top side adapters were the best way to do it... I dunno.
Bump
Old Aug 14, 2013 | 07:15 PM
oakley6575's Avatar
Dammit, now you have me thinking. I have ls3 injectors from my 408 and those bottom adaptors so they would fit in my FAST 102 and I would like to run them in my 4.8L with an NNBS intake. I'm interested if what I have will work in the NNBS intake. Let us know if you find a solution!
Old Aug 14, 2013 | 08:20 PM
I am running the LS3 injectors in a L92 truck intake, same basically as the NNBS, all I had to do was drill out the intake bosses a lil bit to fit the adapters.
Old Aug 14, 2013 | 08:45 PM
javzh's Avatar
im running Fast 85lb ls3 style injectors and i used the fast adapters as well but instead of using the orange o-rings that came with the adapters i went down to oreillys and bought o-orings for an nnbs truck and used those with the adapters. fits perfect. the orange orings are too big. this is on an nnbs intake swap on my 04 silverad0.
Old Aug 15, 2013 | 12:26 AM
I read somewhere that those don't seal around the adapters, and IIRC I tried them on mine as well, and they didn't fit right.
Old Aug 15, 2013 | 01:44 AM
javzh's Avatar
Never heard that.
I bought the injectors off of a member here and he used them the same way on his turboed nnbs.
